fuel pump
steve speed
fuel pump
Post by steve speed » Wed Oct 15, 2008 3:58 pm
has any one tried an electric fuel pump ,,say from an R6/R1 /TDM ,,,,on the tdm site it seems to be a good move what do all the cleaver clogs think ???
idl1975
Re: fuel pump
Post by idl1975 » Wed Oct 15, 2008 5:00 pm
steve speed wrote:has any one tried an electric fuel pump ,,say from an R6/R1 /TDM ,,,,on the tdm site it seems to be a good move what do all the cleaver clogs think ???
What would be the advantage? Thought they existed because of EFI systems and for no other particular reason. [<---- actual serious question :) ]
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
Re: fuel pump
Post by Greg » Thu Oct 16, 2008 12:06 am
I used one for my big tank conversion on the KTM .. no laffin now!
I managed to find a low pressure (1.5-3.0 psi) pump from a ZX6R, which works much like the Facet solid-state pump. It was a piece of cake to fit, just strapped it to the frame member below the tank, although the TRX should be somewhat easier, and took a switched live feed for the pump from the fuse block. There's no recirculation circuit so the pump only pumps when the pressure in the fuel line to the needle valve drops, once the needle valve shuts off the flow the pump stops - valve opens pump pumps... bloody brilliant!
The original 640ADV had a similar diaphragm pump to the TRX - it took freakin aaaaaaages to fill the float bowl from empty, dam nearly flattened the battery! With the pump it goes "vrrrrrup" and in less than 3 seconds the bowl's full and she starts first press...
:motard:
steve speed
Re: fuel pump
Post by steve speed » Thu Oct 16, 2008 11:56 am
greg did you use the std trx tap ? as far as i can see it wont work with the trx tap because the pump sucks on the feed line so i would think it will keep the demand valve shut as i doubt the vacuum will be able to hold the demand valve open ,, what do you think ??
Re: fuel pump
Post by Tarwetijger » Thu Oct 16, 2008 12:50 pm
My YZF has a fuel pump, I always wondered why?
Makes a wzzzzh-sound when contact is turned on.
Carbs are almost indentical to that of the TRX.
Re: fuel pump
Post by phuk72 » Thu Oct 16, 2008 1:28 pm
I had a TRX race bike with an electric pump (from a Mitsubishi car IIRC) that was wired straight to the battery via a simple switch.
Worked fine with the standard fuel tap. Vince (TRXracer) from here has got it now
Re: fuel pump
Post by Greg » Thu Oct 16, 2008 7:25 pm
Steve - I did say it was my KayTeeEmm ... :roll: having said that if you leave the vacuum pipe connected to the inlet I'd guess it'd still work ok as the motor should fire on what's in the float bowls then as soon as the tap's open the pump will have fuel to move...
Best of luck..
G
:motard:
steve speed
Re: fuel pump
Post by steve speed » Thu Oct 16, 2008 9:44 pm
i have got a yzf 750 pump so i tried it on the bench with the old trx carbs and it worked a treat so i set to wiring all the electrics in the bike,, relay ect, went for a start and it pissed fuel out of the overflow ,,i think the float valve jet is to big in the fcr,s and the float cant hold back the pressure ,,anyway Ive put it all back to std while i have a think :evil: :evil: bugger
