Tight front bearings
zod
Post by zod » Wed Jan 07, 2009 10:03 pm
I took my front bearings out for a little (unnecessary) check the other day. When driving the last bearing back into its seat the "bearing-bearing spacer-bearing" unit became very tight. Actually I couldn't spin the bearing by hand at all.
Do anyone know if this is loosening up by it selves when mounted and the bike beeing used? :-k
steve speed
Re: Tight front bearings
Post by steve speed » Wed Jan 07, 2009 11:29 pm
i would not use it in that condition,,, the front bearings are going to get very hot ,,not good ,,did you fit new bearings ? are they any thicker ? the spacer should not be a very tight but it should have no movement side to side ,, if you did use the old bearings they are probably fecked as driving them out usually wrecks them 8-[ 8-[ 8-[ PS, wheel bearings have a nasty habit of catastrophic failure if they are not happy please dont take chances with them [-o<
zod
Post by zod » Thu Jan 08, 2009 12:05 am
Thx for your insight steve.
I used the old ones.
Guess I'll have a set of new bearings coming up then....
zod
Post by zod » Thu Jan 08, 2009 12:22 am
Finally doing a search :roll: (sorry), I see others have discovered this problem too
http://www.trx850.motomaniac.net/forum/ ... ngs#p38205
After what I understand then, you should not drive the bearing fully down the seating on the hub?
More like driving it until the spacer tube is close to tight fit and the bearings still spins freely?
Post by Greg » Thu Jan 08, 2009 12:43 am
Zod...
Exactly right ... expanding on my original post, you can wallop the first race in without fear, but use kid-gloves on the second one. Mine's been fine for 3k miles now...
:motard:
Wombat
Forum Marsupial
Post by Wombat » Mon Jan 12, 2009 2:21 am
yeah, you've gotta have enough space for inner hub spacer tube to float about a bit. Had this problem before and had to find a piece of reo rod and grind a slight step in it so I was able to gently tap the inner race of the opposite bearing to make everything smooth and free again.
