A question for those of you using YZF750 front ends
Kayla
Post by Kayla » Mon Jan 26, 2009 3:47 pm
Do any of you have the preload-only forks, and if so, how do they compare to the standard TRX ones?
idl1975
Re: A question for those of you using YZF750 front ends
Post by idl1975 » Mon Jan 26, 2009 6:32 pm
Kayla wrote:Do any of you have the preload-only forks, and if so, how do they compare to the standard TRX ones?
I think I do ('94 R forks)...will tell you when they're on. :shock:
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
Kayla
Post by Kayla » Mon Jan 26, 2009 6:56 pm
Thanks. I've got a YZF front end here and wondered whether or not to fit it instead of the T'cat forks.
Post by Tarwetijger » Mon Jan 26, 2009 10:30 pm
Are you sure its only preload? I thought also the compression was adjustable (or was it rebound #-o ) .
Well, easy to see: a small flathead screw on top of the preload adjuster. :?:
honkdawillydahonk
Post by honkdawillydahonk » Mon Jan 26, 2009 10:47 pm
Early YZF forks were preload only... PHUK's got a set on his TRX.
idl1975
Post by idl1975 » Tue Jan 27, 2009 7:38 am
honkdawillydahonk wrote:Early YZF forks were preload only... PHUK's got a set on his TRX.
Yep, me too. #-o
They're black though! :D
'76 TY250.
Post by Tarwetijger » Tue Jan 27, 2009 11:05 am
Ah, so there are a lot of different versions.
There are also gold colored ones, I guess those have adjustable preload and compression.
Mine is silver and... fully adjustable. 8)
Kayla
Post by Kayla » Tue Jan 27, 2009 11:58 am
Mine are black with preload only. I know the T'cat forks would give a wider/better range of adjustability but, man, USD forks are cool! :lol:
idl1975
Post by idl1975 » Tue Jan 27, 2009 12:48 pm
And BLACK! :D
Kayla wrote:Mine are black with preload only. I know the T'cat forks would give a wider/better range of adjustability but, man, USD forks are cool! :lol:
'76 TY250.
Post by phuk72 » Tue Jan 27, 2009 12:58 pm
Indeed I have.
And what more do you want? Get them set up for your weight and away you go. Way better than Tcat IMHO
Less to fiddle with (and hence fuk up :wink: )
