Hey, import owners, which brake pads?
Kayla
Post by Kayla » Mon Jan 26, 2009 3:14 pm
I'm in need of some new pads for my bike. It's an import (red frame, white bodywork- you know, one of the fast ones :wink: ) so has Brembo calipers. Where the buggery do I get pads from for them? I don't have a part number for them.
Ta.
edit: Are they the same calipers that were on the XJR400?
http://shop.wemoto.com/pictures.dyn?u=2147872qqq5828053
ynotbiker
Re: Hey, import owners, which brake pads?
Post by ynotbiker » Mon Jan 26, 2009 4:59 pm
ring m and s fitted new ones for me a while back carnt remember which ones sure they will sort it for you or tell you what to order
Post by slow codger » Mon Jan 26, 2009 9:13 pm
Or you could speak to Brembo and ask them, check out their website, PDF download,
http://www.brembo.com/NR/rdonlyres/FC49 ... PADSDR.pdf
Kayla
Post by Kayla » Mon Jan 26, 2009 9:25 pm
slow codger wrote:Or you could speak to Brembo and ask them, check out their website, PDF download,
Thanks Dave :D From that it looks like the pads are the same as lots of recent bikes.
Post by slow codger » Mon Jan 26, 2009 9:31 pm
:D No probs should help those of us with the old n gold brakes, mine work very well with just 2 fingers on the lever, oh and braided lines of course.
Post by cobbadiggabuddyblooo » Wed Jan 28, 2009 11:26 pm
Just out of intrest.. Can you fit blue spots to those forks???
Kayla
Post by Kayla » Thu Jan 29, 2009 4:22 pm
Interestingly, yes you can :D All TRXs used 100mm calipers.
The Brembos are fine though, they just need a smaller diameter m/c as 5/8" (15.8mm) is too big. A Brembo 15mm m/c would be just right but they're pretty scarce.
