Just noticed that the RH rear footrest/exhaust hanger was loose. When I looked closer one of the frame lugs had fractured and the other is going the same way with a hairline crack visible.
Anyone else had this and is there a better way to fix it than trying to weld the broken part of the lug back on (have to do it in situ I guess as it's a big job to strip all the stuff off the frame)
Comments welcome.
Exhaust mountings
Red Rex
Exhaust mountings
- trixynut
Re: Exhaust mountings
I have heard of this before, and mine are 'rusty' around the welds. Must be a weak spot. best solution must be to make it as it was before i.e. weld it back on.
Dave
Dave
- steve speed
they do tend to go if they get rusty , just mig weld it and repaint , if it were me i would take the petrol tank off and the rear bodywork ,disconnect the battery, and have a mate on fire watch with co2 at the ready ,, good luck
- JW-TRX
Mine is the same. Yip, weld is your best bet. Can't think of any other way.
I'd get someone that knows how to weld to do it...You don't want to try it yourself and burn a hole in the frame (As I probably would)
- phuk72
common problemRed Rex wrote:Just noticed that the RH rear footrest/exhaust hanger was loose. When I looked closer one of the frame lugs had fractured and the other is going the same way with a hairline crack visible.
Comments welcome.
stripping down is not really a massive job (rear bodywork is easy and the undertray will 'swing' out of the way if you remove all the mounting bolts) - I'd recommend doing it properly
Red Rex
OK guys ... all sorted now. Thanks for the tips.
Courtesy of Les Liney Vehicle Hire and his MIG welder.
Les is campaigning a blue and white Ducati in the Sound of Thunder this year so if you see him ... give hima cheer. Top bloke
