Can't believe how many variables have popped up just because I need new C&S.
520,525,530 ??????????? AAAAAARRRRRRRRRGGGGGHH.
- G Beale
This is doin my head in now. Just spoke with a company called DK spares regards my replacement chain & sprocket kit. They can get 42T rear & supply with 17T front + 110 link, 520, O ring chain but I'm not convinced regards the chain. I have searched & searched here & the general opinion is that 525 is the norm but the chap at DK is telling me that 520 is the recommended chain for a TRX ???? If I insist on a 525 does this mean the sprockets they supply me with will be too thin ? Turns out they just buy in from B&C express anyhow so I will call them on Monday for a good chat but I value the opinions of you good people so would be interested to hear them.
- steve speed
Re: 520,525,530 ??????????? AAAAAARRRRRRRRRGGGGGHH.
it should be 525,, and if you want the best chain there is, its DID ZVM which has the highest tensile strength of any chain ,, but its not cheap
- Tarwetijger
Funny, I just asked last week about the difference in these numbers, at the bike shop.
Turns out that the number such as 530 says something about the distance between the pins of the chain. So also for the measurements of the tooths of the sprockets. Therefore you can't use a 525 sprocket with a 530 chain for instance (and so on).
Which is a shame, because the YZF I just broke down into pieces had an almost new chain+sprockets, but its 530. The TRXs standard is 525, as already mentioned above.
- phuk72
Standard fit on the TRX is 525.
If DK are telling you differnt they are plain wrong - or trying to shift old stock.
Try B&C Express - they are excellent (and actually know what the are talking about).
- G Beale
Cheers people. I thought it should be 525 but needed to hear it from someone else.
OK all you budding Jullius Sumner Miller's out there...
So how can you potentually gain a few h/power by utilising a 520 chain then. Is it because the actual length ( in MM's )would be shorter on a 520 pitch chain and sprockets and this somehow equates to power in motion???. OR ...Would you get h/p gain to the rear wheel by using 17/43 instead of 16/39 with an extra tooth or two to help pull things along???
Why is it so .. I'm glad you asked me that..
Wait for it...wait for it...
- steve speed
the 520 is thinner so weighs a bit less so you might get the idea its easier to turn ,, but i doubt it ,, you will loose more power with a wrongly adjusted or insuffisant lubed chain than going down one size would help imho
- Kayla
Yeah, it's not so much a gain in bhp more a minimising of losses through the drivetrain. I guess if you can feel the difference you should be racing. Still, the extra 0.5bhp might tip the dyno over the magic 100bhp mark, eh?
- phuk72
A new chain is worth 2 - 3 bhp on a dyno - seen it myselfKayla wrote:Yeah, it's not so much a gain in bhp more a minimising of losses through the drivetrain. I guess if you can feel the difference you should be racing. Still, the extra 0.5bhp might tip the dyno over the magic 100bhp mark, eh?![]()
I am running a 520, and haven't had any issues in excessive wear. Saves a few grams undamped, and also rotational mass. It's cooler than 525
(But I could not tell if the difference is noticeable...)
And I've seen 1-2 HPs difference on a dyno, comparing a dry and a well lubed chain!
- Tarwetijger
phuk72 wrote:A new chain is worth 2 - 3 bhp on a dyno - seen it myself
Really! Didn't know that. So now I know why it's so important to keep the chain clean.HansJ wrote:And I've seen 1-2 HPs difference on a dyno, comparing a dry and a well lubed chain!
- G Beale
Has anyone had dealings with or heard any reports of these chains ?
http://www.iris-chains.com/Ing/CatalagoS.htm
Need to get this sorted ASAP now as my back tyre is looking a bit bald so i want to kill 2 birds with 1 stone so to speak... . 3 if you include my soon to be ex but I would be more than willing to use a 2nd 3rd or 4th stone for her !
why use another stone??? Why not use the old chain and tyre...
Kill 1 bird with two tyres instead...
- phuk72
Never heard of themG Beale wrote:Has anyone had dealings with or heard any reports of these chains ?
Need to get this sorted ASAP now as my back tyre is looking a bit bald so i want to kill 2 birds with 1 stone so to speak... . 3 if you include my soon to be ex but I would be more than willing to use a 2nd 3rd or 4th stone for her !![]()
- steve speed
whats wrong with B&C express ???
