Front sprocket retainer
- slow codger
Re: Front sprocket retainer
- Rural Rat
Max wrote:Regular RH thread.Rural Rat wrote:I am in the process of doing this now. Dumb question before I start. Is the drive sprocket nut LH or RH thread?
Cheers Max, job done.
- steve speed
just been in there to check and clean ,, and its not moved ,, nut , washer .all ok
Good to know you keep your `nut washer` clean and tight.
- steve speed
- Max
- Janitor
Says the man from "jockland"...Mincehead wrote:Nah,too tight is uncomfortable.
Ah but I`m a sassenach,they don`t make kilts long enough for us,we would be exposing our`nuts` to the elements.
Now they might tighten up a bit it`s true but the discomfort would be unbearable even with Araldite,tab washers Loctite or grease!
Commando style and combats,the only way for comfort.
- Wombat
- Forum Marsupial
The retaining washer has 2 flanges on it, so it's designed to be used twice. After that, throw it away. They're only $10AUD at any Yamaha dealer. I've gotta buy a new one when I renew the chain and sprockets around Easter time.
- TonyDevil
i bend the washer over in 3 places, i also use locktite 638 on splines of output shaft, between the sprocket, washer and nut surfaces and on the output shaft thread
i would only ever use OEM front sprockets and replace the washer tab and nut at EVERY retorque
its not worth saving a few quid when the end result writes your engine off
NB : an output shaft is £140, a gasket set is best part of £100, output shaft seal £10 plus oil etc
ie. thats over £250 in parts before you even start looking at labour
TDM900 2003 - commuting tool
Z750 hardtail - project
Hey TonyDevil,I call that the `Belt N Braces` approach.
But hey,if it`s what you need to feel safe,secure and happy and can be arsed to go to that trouble then why not?
As you say,a rebuild is a lot more expensive,and a leg(as your friends)PRICELESS.
