Optimizing the design of the TRX
gregs656
Re: Optimizing the design of the TRX
why would they put the V-Max against those?
I haven't actually seen one on the road yet.
The Hunt Continues . . .
- Kayla
Dunno. I think probably because it was a test of powerful naked bikes and the VMAX doesn't really fit into any category- it's a naked cruisery muscle bike thinger. They liked it but laughed at the price.
lenny
I wish Triumph had made a 21st century Bonneville instead of those fugly retro pieces of crap.With their long tradition of sports twins and their bravery of making unusual bikes like the 675 and Rocket,I hoped it would happen.From an engineering and packaging viewpoint the parallel twin makes a lot of sense. Imagine if Ducati had spent as much time and money developing a parallel twin as it has its "fashionable" V twin.It would kick a 1198's arse.
arrivisto
Although Yamaha continue to refuse to produce a Mk II TRX, it is unlikely that Triumph will give us what we're looking for. The new Bonnie is not so much a rebirth of the original, as a response to the cheek of Kawasaki's W650! The BMW F800 360-degree twin is unremarkable apart from its third "vestigial" conrod to act as a counterbalance. The Wikipedia article on parallel twins - http://en.wikipedia.org/wiki/Parallel_twin - makes some good points, but there is still more to say.lenny wrote:I wish Triumph had made a 21st century Bonneville instead of those fugly retro pieces of crap.With their long tradition of sports twins and their bravery of making unusual bikes like the 675 and Rocket,I hoped it would happen.From an engineering and packaging viewpoint the parallel twin makes a lot of sense. Imagine if Ducati had spent as much time and money developing a parallel twin as it has its "fashionable" V twin.It would kick a 1198's arse.
In my view, Yamaha got it right with the TRX. The 270-crank with balance shafts is the way to go, and I suspect it may become the norm. Kevin Ash in this week's MCN points out that an engine with balance shafts should actually reduce the overall weight of a bike, by allowing a lighter and more effective frame, with an absence of down-tubes. The TRX's 190kg weight is remarkably low for an 850cc twin; especially given its heavy stock silencers and and absence of emphasis on weight-saving.
V-twins are great. I've had Dukes, a Guzzi and a Hesketh (!) and they all had their good points. But look at it in context. After the iconic 1969 CB750, motorcycling had decades of UJM ("Universal Japanese Motorcycle") fours. The current V-twin fad looks as if it is here to stay. Parallel twins are struggling. Even Triumph are having limited success with their twins; and MZ caught a cold with the 1000S.
One needs only to look at the classic British bikes to see the advantages of a parallel twin over a V-twin. It's cheaper to make, with one cylinder head and block, not two. It's much lighter, for the same reason. The carb(s)/fuel injection are easy to position, with logical access to an aircleaner. The twin exhausts exit at the front of the engine, in the blast of cold air. (Of course, in an air-cooled engine, the front forks and wheel severely interrupt the flow of air for cooling; not a problem for a liquid cooled engine). A parallel twin can have sensible exhaust pipes runs, whereas this is never the case with a V-twin. In fact, the rear cylinder on a V-twin is just a menace! It's in the wrong place and gets in the way of the rear suspension. Of course, you can avoid these problems with a Guzzi-style V-twin, but then you end up with handling seriously compromised by the engine's torque reaction!
As I say, Yamaha got it right with the TRX. Nice and light, with the CG low and well forward. The 79bhp output (more like 75!) is nothing special these days, but it's enough for most people. My Guzzi 750 Strada had 48bhp, and while I suppose it was OK, it was just too gutless and boring. The new Bonneville is similarly underpowered. 50bhp is only fine for a real lightweight like an MZ Skorpion. (Even better, the delicious 60bhp MZ Skorpion Replica; there's a mint one on ebay for £4,500!).
Back to the Yamaha: it is perhaps surprising that a 10-valve 850cc bike engine produces only 75 bhp; and the TRX could probably cope nicely with 85 or even 95 bhp. But though it's nice to have lots of power (I've had a VFR750 with 100bhp; a Triumph Sprint 900S with 112, and a Ducati ST4, with 115) there is a law of diminishing returns. More power means more weight, more expense, bigger and more expensive tyres and chains .. the list goes on.
Then there's the issue of one's riding ability - I'm not sure these days that I want more than, say, 90bhp. I'm older than I was! I'll be 60 soon; and although in the past I changed bikes regularly (I've had 42 bikes!), the TRX suits me and I reckon I'm going to stay with it!
- Trixz
All things together.....
We want to hold on to the original frame, switch or upgrade the engine to 6 gears, more CC's, injection, torque, power, other suspension, other swingarm and front end, lights..... hmmm...
Ok, I do think now that it's time for a new concept
exept for the frame
- Kayla
Well, if I could get hold of an FZR400 3TJ frame cheaply I'd like to put the TRX engine into thatTrixz wrote:We want to hold on to the original frame, switch or upgrade the engine to 6 gears, more CC's, injection, torque, power, other suspension, other swingarm and front end, lights..... hmmm...![]()
Ok, I do think now that it's time for a new conceptexept for the frame
- Trixz
I rather lose some more weight, but in track-mode, you can't ride on public roads too luv'Kayla wrote: Lights? Go daytime only (and save a load of weight off the bike at the same time!)
- Kayla
You can over here!Trixz wrote:I rather lose some more weight, but in track-mode, you can't ride on public roads too luv'Kayla wrote: Lights? Go daytime only (and save a load of weight off the bike at the same time!)![]()
- Trixz
Yes you can (probablyKayla wrote:You can over here!
- Kayla
Yes, you may. You don't need lights on a motorcycle over here, but if you do have lights on your bike they all have to be present and in working order. If the lights aren't present, they can't be testedTrixz wrote:Yes you can (probablyKayla wrote:You can over here!), no you may not
(I guess due to MOT right
- Trixz
This is really off-topic Mods feel free to move this part of the thread somewhere else
You must have some exclusion on your registration document then right
The EU regulation (see also @ eur-lex.europa) mentioned it's required.
I found this also, nothing about no lights neccecery (but it's not official I know).
And @ DLVA, I can't find it too, sorry
Anyone who does?
Really, OMGKayla wrote:Yes, you may. You don't need lights on a motorcycle over here, but if you do have lights on your bike they all have to be present and in working order. If the lights aren't present, they can't be testedAll you need to get an MOT (apart from the obvious stuff like good bearings, tyres and brakes) is an electric horn and a legal sized numberplate. I've had a couple of bikes (a TZR250 and a WR250) on daytime only
Though of course you can't ride the bike at night
Anyone who does?
- trixynut
Look at:
http://www.motuk.com/bike/1-1.asp
... and click on 'Headlights' and it says:
I've put a motocrosser on the road before with no lights or indicators, just a 6v horn fitted and a number plate.
This means if you've got lights, they need to work but If you've not got lights, they can't inspect them, and you'll get an 'advisory' note and a daylight-only MOT.This inspection applies to: all machines, except those which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are
. only used during daylight hours, and
. not used at times of seriously reduced visibility
If this situation occurs the vehicle presenter should be issued with an advisory notice recording the above and it should also be recorded on the carbon copy of the VT20
- Kayla
http://www.motuk.co.uk/mcmanual_120.htm
There you go
God bless the idiosyncracies of the UK and EU!
There is lots of heresay and guff on t'internet regarding 'daytime only' MOTs, in reality there is no such thing- it's just recorded on the MOT certificate that the lights are 'not present' and as such an advisory notice is given. Various MOT testers have their own take on the wording of the manual. Some prefer to see a stop/brake light fitted but others have the opinion that it should be all or nothing. Most people who put their bikes through on a daytime only MOT tend to fit a brake light after the MOT as a safety measure more than a legal requirement to do so.
There you go
- Trixz
I would say that it's native or national law then, good for you all!Kayla wrote:http://www.motuk.co.uk/mcmanual_120.htm
- slow codger
