masterbill
by masterbill » Fri Feb 19, 2010 7:48 pm
Hello Kenny,
Daft question time - are you using alot of oil
Does she start well -when hot and cold
Is she smoking alot
Kenny
by Kenny » Sat Feb 20, 2010 1:16 am
not using much oil no starts fine hot or cold no problem there
DOBBO
by DOBBO » Mon Feb 22, 2010 5:28 am
Kenny if the fuel was getting sucked into the motor you would be fouling your spark plugs. I was fouling the RH plug and changed the fuel pump and the problem went away so Im inclined to agree with the leaking float theory. Try and rig up a small catch tank from the fuel overflow pipe , take it for a spin and see if you get any fuel in it.
always expect the unexpected
JW-TRX
by JW-TRX » Mon Feb 22, 2010 12:10 pm
zod wrote:JW-TRX wrote:How is your performance?
With almost twice the fuel going in, you should have around 170 hp
BWAHAHAHAHAHAHA
pom in nz
by pom in nz » Wed Feb 24, 2010 8:00 am
yep something very wrong there,
i cant beleve it still runs ok
i have 150 main jets old needles raised 1 notch, pod filters, custom exhausts and 125,000ks but still get 265 - 275ks to reserve
if its too hard, your doing it wrong.
Kenny
by Kenny » Thu May 20, 2010 11:30 am
Well may have solved the problem here. I had the compression checked and it was 100psi on the left
and 170psi on the right
. So we dug deeper and found the inlet valves never closed on the left
and the right had less than zero clearance. Now reset Ive got 205km on this tank and still not hit reserve much happier now
Thanks for all your replies guyz
by Mincehead » Thu May 20, 2010 1:23 pm
Ah well that`ll do it allright!
Glad it`s sorted Kenny, you must find you`ve got so much more power now too?
Kenny
by Kenny » Sat May 22, 2010 6:32 am
Well now another problem
I ran the tank dry (236km) with the fuel tap set to "on" (tap pointing down) NOT "reserve" how the hell can this happen. I can tell you its a heavy bike to push 1.6km all up hill to home
Pulled the the tnk and removed the tap but cant find anything wrong. All the relevant parts are there filter and 2 brass tubes.
by Mincehead » Sat May 22, 2010 6:37 am
Was there any fuel left in the tank when the lines ran dry?
Kenny
by Kenny » Sat May 22, 2010 4:03 pm
Mincehead wrote:Was there any fuel left in the tank when the lines ran dry?
Not a drop mate it was dry I was shocked to say the least.
by Mincehead » Sat May 22, 2010 5:02 pm
Well the ON position certainly doesn`t allow any leway then, odd because normally you`ll get a cough or two as a warning to switch to reserve!
I`ve done it pal, pushed my Le Mans Mk1 THREE ferkin miles with a flat rear tyre to get her home.
Wouldn`t have trusted leaving her anywhere, much too precious.
I needed a day off work though, my thighs were so pumped up I could hardly walk.
Kenny
by Kenny » Sat Apr 23, 2011 6:08 pm
Hi I have found the cause of my high fuel consumption my fuel tap wont shut off even when I have serviced it.
Kenny
by Kenny » Sun Apr 24, 2011 4:24 pm
Ok fuel tap now an ON OFF RESERVE tap. I modified the original and it works perfectly Im now a happy chappy
cameronjung
by cameronjung » Wed Apr 27, 2011 4:29 pm
I've never hit reserve so I don't know. Got to 300km once though before I decided enough was enough. Usually start looking for a servo around 250.
cameronjung
by cameronjung » Wed Apr 27, 2011 4:30 pm
Oil on the other hand....
