Poor economy
masterbill
Re: Poor economy
Post by masterbill » Fri Feb 19, 2010 7:48 pm
Hello Kenny,
Daft question time - are you using alot of oil :?:
Does she start well -when hot and cold :?:
Is she smoking alot :?:
Kenny
Re: Poor economy
Post by Kenny » Sat Feb 20, 2010 1:16 am
not using much oil no starts fine hot or cold no problem there
DOBBO
Re: Poor economy
Post by DOBBO » Mon Feb 22, 2010 5:28 am
Kenny if the fuel was getting sucked into the motor you would be fouling your spark plugs. I was fouling the RH plug and changed the fuel pump and the problem went away so Im inclined to agree with the leaking float theory. Try and rig up a small catch tank from the fuel overflow pipe , take it for a spin and see if you get any fuel in it.
always expect the unexpected
JW-TRX
Re: Poor economy
Post by JW-TRX » Mon Feb 22, 2010 12:10 pm
zod wrote:
JW-TRX wrote:How is your performance?
With almost twice the fuel going in, you should have around 170 hp 8)
BWAHAHAHAHAHAHA
pom in nz
Re: Poor economy
Post by pom in nz » Wed Feb 24, 2010 8:00 am
yep something very wrong there, :shock: i cant beleve it still runs ok :o
i have 150 main jets old needles raised 1 notch, pod filters, custom exhausts and 125,000ks but still get 265 - 275ks to reserve :D
if its too hard, your doing it wrong.
Kenny
Re: Poor economy
Post by Kenny » Thu May 20, 2010 11:30 am
Well may have solved the problem here. I had the compression checked and it was 100psi on the left :( and 170psi on the right :) . So we dug deeper and found the inlet valves never closed on the left :shock: and the right had less than zero clearance. Now reset Ive got 205km on this tank and still not hit reserve much happier now :D
Thanks for all your replies guyz
Re: Poor economy
Post by Mincehead » Thu May 20, 2010 1:23 pm
Ah well that`ll do it allright!
Glad it`s sorted Kenny, you must find you`ve got so much more power now too? :wink:
Kenny
Re: Poor economy
Post by Kenny » Sat May 22, 2010 6:32 am
Well now another problem :? I ran the tank dry (236km) with the fuel tap set to "on" (tap pointing down) NOT "reserve" how the hell can this happen. I can tell you its a heavy bike to push 1.6km all up hill to home :twisted:
Pulled the the tnk and removed the tap but cant find anything wrong. All the relevant parts are there filter and 2 brass tubes.
Re: Poor economy
Post by Mincehead » Sat May 22, 2010 6:37 am
Was there any fuel left in the tank when the lines ran dry?
Kenny
Re: Poor economy
Post by Kenny » Sat May 22, 2010 4:03 pm
Mincehead wrote:Was there any fuel left in the tank when the lines ran dry?
Not a drop mate it was dry I was shocked to say the least.
Re: Poor economy
Post by Mincehead » Sat May 22, 2010 5:02 pm
Well the ON position certainly doesn`t allow any leway then, odd because normally you`ll get a cough or two as a warning to switch to reserve!
I`ve done it pal, pushed my Le Mans Mk1 THREE ferkin miles with a flat rear tyre to get her home.
Wouldn`t have trusted leaving her anywhere, much too precious.
I needed a day off work though, my thighs were so pumped up I could hardly walk. :lol:
Kenny
Re: Poor economy
Post by Kenny » Sat Apr 23, 2011 6:08 pm
Hi I have found the cause of my high fuel consumption my fuel tap wont shut off even when I have serviced it.
Kenny
Re: Poor economy
Post by Kenny » Sun Apr 24, 2011 4:24 pm
Ok fuel tap now an ON OFF RESERVE tap. I modified the original and it works perfectly Im now a happy chappy :D
cameronjung
Re: Poor economy
Post by cameronjung » Wed Apr 27, 2011 4:29 pm
I've never hit reserve so I don't know. Got to 300km once though before I decided enough was enough. Usually start looking for a servo around 250.
cameronjung
Re: Poor economy
Post by cameronjung » Wed Apr 27, 2011 4:30 pm
Oil on the other hand....
