Ah I thought so...bobtrx wrote:It's called a joke , bike has small speedo reading must be new so sell it for more money. It's not really for sale
Working on cil.head - Your thoughts
- Tarwetijger
Re: Working on cil.head - Your thoughts
Fitted an other valve today. It's scrubbed in and the clearance doesn't even need adjustment!
So finally I can get the engine back together.
- Trixz
Sounds like you're eager to ride with this kind of weatherTarwetijger wrote:Fitted an other valve today. It's scrubbed in and the clearance doesn't even need adjustment!So finally I can get the engine back together.
- Tarwetijger
There's a lot more to do; have to take a look on the chain and the seal behind the front sprocket. If that is all done, I'll take it to a dyno, to set up the carbs properly!Trixz wrote: Sounds like you're eager to ride with this kind of weather*it's cold, a bit snow and ice outside
- Tarwetijger
The engine is back together and it run shortly today. It runs very smooth and quiet, and no little black dots on my hand if I hold it behind the exhaust!
I also put the bellmouths on. Now I finally know what people mean if they're talking about that typical flatslide sound!
Now I need some new air filter. Seperate K&N pod filters won't work, because the flange can't get over the bellmouths.
I need something like this:
Any suggestions on this and where to get it?
PS: How do other bellmouths-users do this??
- Killerwhale
I have this:Tarwetijger wrote:The engine is back together and it run shortly today. It runs very smooth and quiet, and no little black dots on my hand if I hold it behind the exhaust!![]()
- bobtrx
- JL
Great to hear it is all going now. Well done
- Tarwetijger
Ah:Killerwhale wrote: I have this:
http://ramair-filters.com/motorbike/fra ... rbike.html
Looks good. Now I only have to take some measurements of the bike and find a place to order them.
Cheers! First the bike wouldn't start, but putting some petrol in the tank solved the problem.JL wrote:Great to hear it is all going now. Well done
- Killerwhale
Tarwetijger wrote:Cheers! First the bike wouldn't start, but putting some petrol in the tank solved the problem.
Taken from memory it´s the MS-009...you´ll have to buy it in pairs so if you don´t want a spare i can buy it from ya....
Reason: ... fixed the quote bit for you :-)
- Tarwetijger
Are you sure?Killerwhale wrote:Taken from memory it´s the MS-009...you´ll have to buy it in pairs so if you don´t want a spare i can buy it from ya....
Here 's what available':
You only have to look at the last two columns, neck diameter and between centres.Part Number Overall length Overall width Overall height Neck diameter Between centres
MS-006 170 114 65 47 77
MS-007 160 110 65 47 72
MS-008 160 108 65 47 74
MS-009 177 90 100 47 86
MS-010 177 90 110 47 86
MS-011 197 90 75 47 107
MS-016 105 105 75 29 74
MS-017 177 90 110 29 85
MS-018 177 90 110 29 85
Note: All the above sock filters come packed in pairs.
I measured neck diam 42,5 mm, between centres 99 mm.
Looks like none of them listed, will fit nicely. Or am I exaggerating by being so accurate? How flexy are those filters?
I think I will go for MS-011, as it comes the closest and theoretically has enough material between the holes.
- Killerwhale
- Tarwetijger
Cheers for looking that up, but MS-009 doesn't make sense to me.Killerwhale wrote:http://trx850.motomaniac.net/forum/view ... &hilit=009
I found a lot of adverts on evilbay from ramair and send my question to them.
- bobtrx
If you have the same stacks as these then MS-009 is the correct filter
catch ewe later bob
I just bought air filter foam and got the measurements of the ramair filter to fit the blue bellmouths ms009 and made my own and cost me bugger all.. Its done about 10,000km so far and still working well...
- Tarwetijger
I don't have the same stacks because I have Mikuni TDMR flatslides, but I suppose the dimensions will be more or less the same.bobtrx wrote:If you have the same stacks as these then MS-009 is the correct filter
http://i64.photobucket.com/albums/h169/ ... amair4.jpg
http://i64.photobucket.com/albums/h169/ ... amair1.jpg
