Sod it
Sod it
Post by slow codger » Thu Apr 01, 2010 12:38 pm
:evil: Bike didnt get its Mot as frame has cracked around the rear exhaust mounting point! hopefully will be sorted by next week.
Knew the horn wasnt working so had a look at that, wire had fell off!
cleaned up contacts for headlight, that works again.
Just the bloody frame!, will be having a new front tyre as well, will sort out the weeping valve at least (put an o ring in the dust cap to seal it last year)
JL
Re: Sod it
Post by JL » Thu Apr 01, 2010 12:42 pm
What a bummer, hope it doesn't take too much work to fix!
Re: Sod it
Post by Jak » Thu Apr 01, 2010 1:10 pm
:( That's kinda where my frame had a hole too.
Hope you get it sorted soon!! (gotta be back on the road by the 11th!!!)
Re: Sod it
Post by phuk72 » Thu Apr 01, 2010 1:32 pm
Picky MOT tester. Did he explain the reason for failing?
TonyDevil
Re: Sod it
Post by TonyDevil » Thu Apr 01, 2010 2:29 pm
i had the same thing and my old neighbour welded some new mounts for me
canne remember if i ever posted the pics....
edit: heres my old topic http://trx850.motomaniac.net/forum/view ... =37&t=4866 no pics, will try and dig them out
TDM900 2003 - commuting tool
Z750 hardtail - project
Re: Sod it
Post by slow codger » Thu Apr 01, 2010 2:38 pm
:evil: Left hand mount (as looking from the back)! It moves (and widens the crack) when you pull out on the exhaust! Don't know what all the fuss is about Pete, I havent got a pillion to carry!!!. It will be sorted by the 11th, Jak (If I know where we're going).
Re: Sod it
Post by Jak » Thu Apr 01, 2010 4:46 pm
slow codger wrote:Left hand mount (as looking from the back)! It moves (and widens the crack) when you pull out on the exhaust!
Well don't pull the exhaust then ... you'll make it worse and burn your hands ... see, blondes know mechanical stuff sometimes :roll: :twisted: :twisted: :twisted:
Re: Sod it
Post by slow codger » Thu Apr 01, 2010 5:26 pm
:whoopass: There are a lot of jokes about blondes!! Anyhow about time you got your bike on the road and rode that instead of driving down!
Red Rex
Re: Sod it
Post by Red Rex » Thu Apr 01, 2010 7:19 pm
Yeah, mine broke there too. Only noticed it when I was fitting the 'quiet' cans ready for the MOT.
Took it to my local Van Hire man (who races a Ducati in his spare time)
£5 minutes and £5 fixed it. :D
Re: Sod it
Post by Jak » Thu Apr 01, 2010 9:36 pm
slow codger wrote::whoopass: There are a lot of jokes about blondes!! Anyhow about time you got your bike on the road and rode that instead of driving down!
Yeah yeah ... I know ... finally moving it next week so then all I've gotta do is learn how to fix it, fix it and get it MOT'd :shock:
Seems like it's a common weak spot on the TRXs then (I have a feeling I've said that before :-k )
Smithers
Re: Sod it
Post by Smithers » Fri Apr 02, 2010 5:30 am
Thanks for that. I checked my LH mount to find it had nearly departed from the subframe..... have just MIG'ed it and the paint is drying as I type..... Cheers
Re: Sod it
Post by slow codger » Thu Apr 08, 2010 6:34 pm
:shock: Look at the rear mount, there is a small box section between the bolts! that part is not welded to the frame! (Except it is on mine now).
Just being sprayed and drying, will be ready for Sunday.
