2-1 headers (again!)
Kayla
Post by Kayla » Thu Aug 05, 2010 11:08 am
Out of curiousity, would there be interest in me having some stainless 18swg 2-1 headers made up to suit the TRX? They'd fit the standard bike around the standard swingarm and rearsets, using the standard right side exhaust hanger. They'd be standard bore at the headers but have a 50mm exit on the right where the standard pipe is, with a 50mm link pipe to suit any 50mm can and cut around 10kg off the standard system, or around 3kg if you're already using race cans. Obviously my over-use of the word 'standard' here is trying to emphasise the fact they'd fit straight on to A.N Other TRX :D
I'd have to order 5 sets initially and they'd probably cost around £300 for stainless (they also do titanium but that would be £££££ :shock: )
Re: 2-1 headers (again!)
Post by Mincehead » Thu Aug 05, 2010 11:17 am
I`m sure folk would be interested Kayla.
Right folks, here`s the poll:
Votes FOR 2 into 1 Stainless headers assemblies and interest, roll-up, roll-up?
Post by Tarwetijger » Thu Aug 05, 2010 9:10 pm
Sorry Kayla for being an a$$ but isn't it cheaper to modify this one to suit a TRX?
http://www.kedo.de/com/ssl/php/art_deta ... 7aabe9973e
Post by Mincehead » Thu Aug 05, 2010 9:42 pm
That link`s not working Tarwe. :wink:
Kayla
Post by Kayla » Fri Aug 06, 2010 8:52 am
Tarwetijger wrote:Sorry Kayla for being an a$$ but isn't it cheaper to modify this one to suit a TRX?
If it's the one I'm thinking of, yes it probably would be cheaper to heat and bend that one, but it wouldn't be hand made in Britain and TIG welded together, and it would probably have a 38mm exit on the right rather than a 50mm one ;) I think they're the same ones Sandy Bike Spares sell that are made in the Far East.
So, not much interest in a 2-1 exhaust then? :lol:
devlin
Post by devlin » Fri Aug 06, 2010 11:49 am
I'd be keen but not for some time and I'm far away.
Post by Killerwhale » Fri Aug 06, 2010 12:46 pm
Kayla wrote:If it's the one I'm thinking of, yes it probably would be cheaper to heat and bend that one, but it wouldn't be hand made in Britain and TIG welded together, and it would probably have a 38mm exit on the right rather than a 50mm one ;) I think they're the same ones Sandy Bike Spares sell that are made in the Far East.
Why not a big bore (42mm-ish) 2-1 with "powerbombs" ending up in 60mm high mount or even under seat? I have 60mm on my Akra and there are PLENTY 60mm cans on evilbay. Then i would probably cough up some dosh! 8)
Powerbomb:
Skip6752008
Post by Skip6752008 » Fri Aug 06, 2010 1:01 pm
G Day
I have a 60mm Akrapovic Hex Carbon Can which I am planning to match to a 2-1 header setup.
Was hoping to source a akra system then have the link pipe mod'd. - other option was a special fab.
Post by phuk72 » Fri Aug 06, 2010 1:10 pm
Skip6752008 wrote:G Day
you can either have the link pipe daimeter stretched (just need to find an engineering firm with a pipe spreader) or reduce the inlet (can be tapered or replaced by anyone who can weld and has access to a short piece of pipe)
Kayla
Post by Kayla » Fri Aug 06, 2010 2:10 pm
Powerbomb:
The extra work would push the price up too much, and there's no dyno evidence to back up a 'powerbomb' on the TRX engine. I understand the principle, it's like a mini expansion chamber, but I don't think the cost of the extra work would be borne by people buying the pipes.
The exhaust company can produce the headers in 1.5" (standard) or 1.75" (42mm internal) pipe. The 1.5" headers would have a 2" (50mm) link/collector and the 1.75" headers would have a 2.5" (60mm internal) link/collector.
So, is there any interest in a big bore, plain tube stainless exhaust? The exhaust company also have CNC machining tools so would produce a stainless split header clamp to replace the frankly ridiculous standard one piece Yam one.
Kenny
Post by Kenny » Fri Aug 06, 2010 2:16 pm
Kayla you have email...... Also can the company do big bore 2-1-2?
Post by Killerwhale » Fri Aug 06, 2010 3:36 pm
You´re right, PB are a really nice dB killer as well.
But yeah, i would be interested and i would guess me mate is as well...seems he got the bug and going for flatties and your R6 adapter :-)
...and my akrapovic would generate some good money on the evilbay....
Kayla
Post by Kayla » Sat Aug 07, 2010 5:24 am
Kenny wrote:Kayla you have email...... Also can the company do big bore 2-1-2?
Hi Kenny, the company could do a 2-1-2 but they'd need a bike to work from- they can't use mine because it's only got one exhaust mount on the frame.
So, Killerwhale and his friend are two, plus me is three, any more? They'll do a minimum of five, after that (once they've made a jig for the headers) they can do them to order but they want a minimum of five orders initially to make it worth their while, which is fair enough.
Kenny
Post by Kenny » Sat Aug 07, 2010 10:21 am
How much would a 2-1-2 be Kayla?
Post by Killerwhale » Sat Aug 07, 2010 1:09 pm
Kenny wrote:How much would a 2-1-2 be Kayla?
Was thinking about this a bit....
On my standard headers i have something called a supercan and it does wonders for the low/mid power.
Kinda same as the link down low on the standards but theese actually make a great difference, sold one set to someone on the forum as well and his dip in mid power was gone after the change! =D>
Can we have something similar??
Pic:
