What's this?
Rod.s
What's this?
Post by Rod.s » Fri Apr 15, 2011 12:14 pm
Ok i don't know every part of this bike...yet... so when i removed the radiator cap this fell on the floor, must have been held on by phantom glue. So if it's now on the floor then where did it come from :roll:
Rod
schmiffee
Re: What's this?
Post by schmiffee » Fri Apr 15, 2011 12:41 pm
It goes under the radiator cap and has a bolt that goes through the cap into the thread. It makes it harder to remove the radiator cap to tamper with the fluids...
Rod.s
Re: What's this?
Post by Rod.s » Fri Apr 15, 2011 12:48 pm
schmiffee wrote:It goes under the radiator cap and has a bolt that goes through the cap into the thread. It makes it harder to remove the radiator cap to tamper with the fluids...
Thanks Mr Smith.
So I'm now missing a bolt! must have fallen off like all the other bolts that are missing, that, or there is a bolt thief in my aera :?
rod
Re: What's this?
Post by Mincehead » Fri Apr 15, 2011 5:33 pm
It`s not a critical part of the bike, mine hasn`t even got one but I guessed what it was when you mentioned radiator cap. Never even seen one before! :lol:
M.V.
Re: What's this?
Post by M.V. » Sat Apr 16, 2011 1:28 am
Mincehead wrote:It`s not a critical part of the bike, mine hasn`t even got one but I guessed what it was when you mentioned radiator cap. Never even seen one before! :lol:
Mine fell off a while ago... Must but some more locktite...
Rod.s
Re: What's this?
Post by Rod.s » Sat Apr 16, 2011 2:26 am
Yep I've been using 222 locktite on everything i touch on this bike, found out yesterday that one of the bolts holding the rear brake assembly (foot peg etc) had gone missing, now the new one and original are 222 on :D
Rod
rbaron25
Re: What's this?
Post by rbaron25 » Sat Apr 16, 2011 4:06 am
I will give you all your bolts back if you let her go slowly with the $500 ransom...
I didn't see you...
Cause you didn't bloody look!
Re: What's this?
Post by fung » Sun Apr 17, 2011 9:07 am
Rod.s wrote:Ok i don't know every part of this bike...yet... so when i removed the radiator cap this fell on the floor, must have been held on by phantom glue. So if it's now on the floor then where did it come from :roll:
Rod
remember to put it on so it holds tension against the cap undoing because it can be put on backwards.
fung 8)
