Frame Repairs?
TRiXy
Frame Repairs?
Post by TRiXy » Fri Apr 29, 2011 1:07 pm
Hi all,
Recently I discovered that I've managed to tear a hole in the frame on my bike. Fortunately, it's where the left exhaust hanger & pillion foot peg mount, so it's out of the way of serious stuff (I never carry a pillion). At the moment it's held back together with cable ties, but obviously I need to get it repaired properly. Does anyone know what material the frame is made of? I've got access to a MIG, so I can take care of the repairs myself if it's nothing too fancy, but I might have to call on some favours if I need TIG.
Any advice would be appreciated.
Thanks and Regards
Current Rides:
2010 YZF-R1 - Stock, but still awesome.
1995 Import Spec TRX - Yoshi Pipes & Jet Kit
Kayla
Re: Frame Repairs?
Post by Kayla » Fri Apr 29, 2011 1:14 pm
TRiXy wrote:Hi all,
Thanks and Regards
The frame is just normal steel, but it's very thin where you're going to weld so be careful!
Re: Frame Repairs?
Post by slow codger » Sun May 01, 2011 4:53 pm
:? Appears a common weak point, had to have mine welded there, mine was cut, a smaller bore pipe inserted then welded up! Do you have aftermarket pipes, and have you had to even the spacing up?
TRiXy
Re: Frame Repairs?
Post by TRiXy » Mon May 02, 2011 12:59 pm
Thanks for the tips guys... I'll do what I can regarding inserting a thinner section of tube inside.
Yes it's got aftermarket Pipes, Yoshimura Titans. They were installed on the bike when i got it, but I've had them off a few times, and they never seemed to be putting any unusual load onto the mounting points.
Current Rides:
