G'day! I bought my bike on eBay sight unseen... No problems
Nah, it wasn't too bad.
Same as above really:
FIRST: CHECK THE OIL!
There's no oil pressure light. To check the oil, you need to run the bike for 10 minutes, then shut the engine off, hold the bike level & see if any oil shows in the window. If not, top it up & try again.
Plenty of TRX's have thrown big ends (usually on the left) because of lack of oil, my first engine included.
Fork springs to suit your weight, change the oil to 15W while you're there, unless you only weigh 50kg, in which case it'll be fine
If you do any night riding fit a HID headlight, or a twin projector headlight from an FZR, or preferably both!
Blue/gold/silver spot calipers from R1/R6/FZ1 bolt straight on & are a good upgrade. Good sintered pads too.
Braided lines, K&N filter, either put in a Factory Pro jet kit & emulsion tubes & set the carbs up properly (they run very rich stock, & get worse as the e tubes wear) or replace the carbs with FCR's ($1000-1200, but very good bang for you buck)
Pilot Road 2's are a great tyre for the TRX...
Yes, definitely set everything back to standard, there's a service manual floating around somewhere...
Case in point; when I got mine, the top of the fork stanchions were flush with the top yoke/clipons, little did I know there should have been 18mm of stanchion poking through there
There were a few weird steering (or lack of) moments, let me tell you!
Other than that, I think you'll find most everything has been covered on here, if not, we're more than happy to hear about it
