It fires up fine, adjust idle down but there's a lot of exhaust smoke once it warms up and that does not take long, maybe 20-30 seconds. I am concerned about the smoke and the rate at which it warmed up (overheating?) - checked the rad to make sure hot coolant is being pumped around - OK, pretty hot but temperature reading barely off the line at 60. More smoke on rider's left side than right, cans look like Clint Eastwood's Magnum after a spree when I kill the engine.
So, the history to help diagnose:
Bought it, rode it home 8 miles. No smoke noticed at that point but it could have been there.
Slowly took it apart: tank airbox, rad, carbs & thermostat to get in about and clean as much as possible - what a mess of hidden salt and crud!
The choke on the carbs has seized completely so dismantled and rebuilt that bit. Took off diaphragms and float bowls to have a look for damage (looked OK) and squirt through with carb cleaner. Did NOT adjust any screws.
Put in new plugs (wemoto sent 9's though I think 8's are correct)
Changed to K&N air filter from std
Changed coolant and oil & filter (why the hell did they make the filter such a PITA to get at?) - it's taken 3.7litre so far but nothing in the gauge window yet!
I can't think what this might be unless I upset the carb setting or didn't put it back properly on the rubbers. Ideas welcome but I'm running out of time before I head off for a couple of weeks ...
