R6 Rear Shock...?
M.V.
R6 Rear Shock...?
Post by M.V. » Fri Jul 01, 2011 3:36 am
Apparently I've bought an R6 rear shock from a 2001 model... Go eBay!
Any idea if this will fit my TRX?
M.V.
Re: R6 Rear Shock...?
Post by M.V. » Sat Jul 02, 2011 12:25 am
Ok, Kayla set me straight on this one, no, it won't fit. #-o
Oh well.
Post by coxylaad » Mon Jul 04, 2011 4:14 pm
:lol:
I am sorry but that was good comic timing :lol:
M.V.
Post by M.V. » Tue Jul 05, 2011 1:07 am
Try the veal, I'm here all week!
mariom
Post by mariom » Tue Jul 05, 2011 12:05 pm
M.V.
Post by M.V. » Tue Jul 05, 2011 1:26 pm
Thanks for the heads up Mario, but that's Kayla on here, I've already ordered the adaptor from her, just need to find the right shock, third time lucky!
Oh, BTW, the shock from the american R6S won't fit, just FYI.
Like I said, third time lucky.
Post by cobbadiggabuddyblooo » Wed Jul 06, 2011 8:20 am
06 onwards... someone mentioned about the red spring 06/07 model may have a progressive spring and check the later silver model ones may have a linear spring.
M.V.
Post by M.V. » Wed Jul 06, 2011 11:12 am
cobbadiggabuddyblooo wrote:06 onwards... someone mentioned about the red spring 06/07 model may have a progressive spring and check the later silver model ones may have a linear spring.
I'm looking at a silver one at the moment, do I want progressive or linear?
Post by cobbadiggabuddyblooo » Wed Jul 06, 2011 11:42 am
I'd be happy with a linear,constant rate.. silver will look nice too.
M.V.
Post by M.V. » Fri Jul 08, 2011 2:06 am
Well, I made another stupid offer (06/07 model, with the correct fitting!) & it was accepted, $65 us dollar plus postage, should work out under $100 Aus.
I got the red one, I can always change out the spring later, it might be sprung a little soft for me anyhow...
Marty Moose
Post by Marty Moose » Fri Jul 08, 2011 10:52 am
How much do you weigh ??
MM
M.V.
Post by M.V. » Sat Jul 09, 2011 12:39 am
Marty Moose wrote:How much do you weigh ??
MM
Heaps!
Nah, about 100kg give or take. Using the R6, Race Tech calc reckons a 10.3kg/mm (or 10.5 for racing) spring, the nearest they have is 10.7kg/mm. Standrard spring is 9.8 apparently.
About the same for the TRX, but I think their imperial to metric conversion is a bit off, unless it uses weight distribution...
Marty Moose
Post by Marty Moose » Sat Jul 09, 2011 9:58 am
Yeh they normally are a bit low in rates for the rear if you use Loaded and static sag values. I raced an R6 they said 9.3 I ended up with a 10.5 and I'm 83kg. I'm going to fit a 10.5 to my TRX. 100 Kgs I'd be looking round 11.0 to 11.5 or else you will run low static to get a reasonable loaded value.
MM
M.V.
Post by M.V. » Wed Jul 13, 2011 6:30 am
Marty Moose wrote:Yeh they normally are a bit low in rates for the rear if you use Loaded and static sag values. I raced an R6 they said 9.3 I ended up with a 10.5 and I'm 83kg. I'm going to fit a 10.5 to my TRX. 100 Kgs I'd be looking round 11.0 to 11.5 or else you will run low static to get a reasonable loaded value.
MM
Thanks MM, I'll give it a try with the standard shock & see how it goes, replacement spring won't cost too much if I decide I need on in the future anyhow.
Just waiting on the packages now.
