R6 Rear Shock...?
- M.V.
R6 Rear Shock...?
Apparently I've bought an R6 rear shock from a 2001 model... Go eBay!
Any idea if this will fit my TRX?
- M.V.
Re: R6 Rear Shock...?
Ok, Kayla set me straight on this one, no, it won't fit.
Oh well.
Oh well.
I am sorry but that was good comic timing
- M.V.
Try the veal, I'm here all week!
mariom
- M.V.
Thanks for the heads up Mario, but that's Kayla on here, I've already ordered the adaptor from her, just need to find the right shock, third time lucky!
Oh, BTW, the shock from the american R6S won't fit, just FYI.
Like I said, third time lucky.
06 onwards... someone mentioned about the red spring 06/07 model may have a progressive spring and check the later silver model ones may have a linear spring.
- M.V.
I'm looking at a silver one at the moment, do I want progressive or linear?cobbadiggabuddyblooo wrote:06 onwards... someone mentioned about the red spring 06/07 model may have a progressive spring and check the later silver model ones may have a linear spring.
I'd be happy with a linear,constant rate.. silver will look nice too.
- M.V.
Well, I made another stupid offer (06/07 model, with the correct fitting!) & it was accepted, $65 us dollar plus postage, should work out under $100 Aus.
I got the red one, I can always change out the spring later, it might be sprung a little soft for me anyhow...
Marty Moose
How much do you weigh ??
MM
MM
- M.V.
Heaps!Marty Moose wrote:How much do you weigh ??
MM
Nah, about 100kg give or take. Using the R6, Race Tech calc reckons a 10.3kg/mm (or 10.5 for racing) spring, the nearest they have is 10.7kg/mm. Standrard spring is 9.8 apparently.
About the same for the TRX, but I think their imperial to metric conversion is a bit off, unless it uses weight distribution...
Marty Moose
Yeh they normally are a bit low in rates for the rear if you use Loaded and static sag values. I raced an R6 they said 9.3 I ended up with a 10.5 and I'm 83kg. I'm going to fit a 10.5 to my TRX. 100 Kgs I'd be looking round 11.0 to 11.5 or else you will run low static to get a reasonable loaded value.
MM
MM
- M.V.
Thanks MM, I'll give it a try with the standard shock & see how it goes, replacement spring won't cost too much if I decide I need on in the future anyhow.Marty Moose wrote:Yeh they normally are a bit low in rates for the rear if you use Loaded and static sag values. I raced an R6 they said 9.3 I ended up with a 10.5 and I'm 83kg. I'm going to fit a 10.5 to my TRX. 100 Kgs I'd be looking round 11.0 to 11.5 or else you will run low static to get a reasonable loaded value.
MM
Just waiting on the packages now.
