rotor puller
eddie
eddie
zednine
Re: rotor puller
You can borrow mine if your local
eddie
Re: rotor puller
Cheers zednine I will take you up on that
Il see you right for it.
I'm in the proccess of getting a new alti
Once I've got it il pm you for your address
I'm in Manchester so its not to far
God is my judge
zednine
Re: rotor puller
No problem ....... do you need to swap the rotor if you are just changing the alternator ?
Chris
Chris
Re: rotor puller
Nope you don`t! The alternator stator is secured on the inside of the alternator casing with the ignition pick-up, the rotor can remain in place.
eddie
Re: rotor puller
Aaaahh I see what you mean
The manual seems to point to it being
On the other side of the rotor
Or maybe its just me
God is my judge
