Vee Two cams
Re: Vee Two cams
Post by Mincehead » Wed Jul 20, 2011 7:38 pm
Is burty coming down with something nasty Phuk? :lol:
Re: Vee Two cams
Post by phuk72 » Thu Jul 21, 2011 7:26 am
Mincehead wrote:Is burty coming down with something nasty Phuk? :lol:
LOL
In fairness, he ruins other biks on his commute and saves the TRX for best :D
megatronics
Re: Vee Two cams
Post by megatronics » Wed Jul 27, 2011 9:02 am
aren't the gains on a trx to be seen more in the torque than the hp?
Re: Vee Two cams
Post by phuk72 » Wed Jul 27, 2011 9:26 am
megatronics wrote:aren't the gains on a trx to be seen more in the torque than the hp?
Doesn't matter. It's where the peak power / torque is that makes a difference
Re: Vee Two cams
Post by dandywarhol » Wed Jul 27, 2011 11:02 am
I've got Kent reprofiled cams, ported head, 0.5 up on the compression ratio, Power Commander and Akras on my TDM9 - doesn't make a huge amount of power but a healthy 69 at the wheel @ 5000 rpm - now that's useable on the road. As folks say - torque is more important unless your on the track and you have the gear ratios to suit........................
mickjmag
Re: Vee Two cams
Post by mickjmag » Fri Jul 29, 2011 1:42 pm
phuk72 wrote:I can tell you from experince that cams alone (on a stock motor) are worth little more than a couple of bhp.
With gas flowing (on top of free flowing pipe and air box) you might see 10 bhp but nothing more.
I have dyno charts somewhere that I can post.
What phuk said!!
Also have heard that the trx valve train is not up to the task with Veetwo cams.
Big cost no gains without other costly mods :-k
Cheers Mick
Bruceconsidered
Re: Vee Two cams
Post by Bruceconsidered » Thu Aug 04, 2011 12:38 pm
Hot cams usually narrow the power band and shift it higher in the rev range. Fuel consumption will also increase. It took me many years and thousands of wasted dollars to realise you don't need to hot the engine up especially if you are not red lining your bike at every gear change. It is much cheaper to buy a more powerful bike. How many of your friends ride their bike to the limit? I would suggest they ride with plenty in reserve therefore putting additional stress on your engine and drive train seems pointless. I do appreciate that it is nice to have a bike that is special, sounds nice and goes harder than you dare to ride. In conclusion do what ever you like and gives you pleasure and enjoy the ride.
Re: Vee Two cams
Post by phuk72 » Thu Aug 04, 2011 12:49 pm
Bruceconsidered wrote:Hot cams usually narrow the power band and shift it higher in the rev range. Fuel consumption will also increase. It took me many years and thousands of wasted dollars to realise you don't need to hot the engine up especially if you are not red lining your bike at every gear change. It is much cheaper to buy a more powerful bike. How many of your friends ride their bike to the limit? I would suggest they ride with plenty in reserve therefore putting additional stress on your engine and drive train seems pointless. I do appreciate that it is nice to have a bike that is special, sounds nice and goes harder than you dare to ride. In conclusion do what ever you like and gives you pleasure and enjoy the ride.
you'll find that most on here have tuned for midrange and useability on the road. And that a lot of owners have previously owned more powerful bike - somer have even sold TRXs to move onto pastures new and come back again!
I've spent a good chcunk of money on my bike but don't regard any of it as wasted.
But I agree with you, most people don't need more power - but that doesn't stop them wanting it ;)
Welcome to the site btw.
