More FCR Questions
SDN
More FCR Questions
Post by SDN » Sat Aug 06, 2011 9:16 am
Can you use the standard TRX throttle cables with FCR's?
If you can't what cables do you need and where do you get them?
Has anyone got any idea of the part number and cost of the carb rubbers to fit the FCR's and the best place to get them?
Re: More FCR Questions
Post by Killerwhale » Sat Aug 06, 2011 9:41 am
SDN wrote:Can you use the standard TRX throttle cables with FCR's?
I did use standard first time, but you´ll have to cut ´em and buy those wire stop screw thingies.. :)
Post by Mincehead » Sat Aug 06, 2011 10:22 am
Wire stop screw thingies? Solderless nipples perchance Kw? :lol:
Post by Killerwhale » Sat Aug 06, 2011 10:34 am
Mincehead wrote:Wire stop screw thingies? Solderless nipples perchance Kw? :lol:
That´d be the one! :)
SDN
Post by SDN » Sat Aug 06, 2011 1:53 pm
Cheers guys, what about buying carb rubbers?
Post by Killerwhale » Sat Aug 06, 2011 2:03 pm
SDN wrote:Cheers guys, what about buying carb rubbers?
I just bought a pair from DE on ebay, think they where 12€
SDN
Post by SDN » Sat Aug 06, 2011 5:14 pm
you got a part number?
Post by Mincehead » Sat Aug 06, 2011 7:53 pm
You can order them from Allens in the UK too, I buy plenty of stuff from them, good guys :wink: :
http://www.allensperformance.co.uk/prod ... folds.html
Post by trixynut » Sat Aug 06, 2011 10:35 pm
I'm sure I used standard carb rubbers?? (to connect carbs to cylinders)
Post by Killerwhale » Sat Aug 06, 2011 10:39 pm
trixynut wrote:I'm sure I used standard carb rubbers?? (to connect carbs to cylinders)
Yep rubbers standard...just have to take ´em up to 41mm
Tourqe-a-holic
