Big bore headers available soon
Re: Big bore headers available soon
Post by Mincehead » Mon Oct 03, 2011 9:10 am
Don`t see why not, can you use a TIG plant?
SDN
Post by SDN » Mon Oct 03, 2011 9:28 am
coxylaad wrote:I scored a top spec tig welder from work when they closed the fab shop, and an industrial pipe bender. If anyone has any idea of using either of them and are willing to give me a hand we could have a go ourselves!
this type of pipe bender:
and this type of welder:
How hard can it be :D
That sort of pipe bender will not work on thin walled tube, you need the type with followers, also if we are wanting tapered headers, the bend former will need to be tapered. I used to work at Aeroquip, and we bent a lot of tube, usually with automatic CNC benders. It is quite tricky
Post by Mincehead » Mon Oct 03, 2011 9:30 am
I think coxylaad was referring to making up the collector sections only (?) to enable a 2 into 1 or 2 into 2 can set up to be used. :wink:
Post by coxylaad » Mon Oct 03, 2011 11:17 am
well I was talking about possibly making the lot!
I have other options for pipe bending too. I work very closely with a company that supplies tubes all over the world and I think they have a big bender
andyaber
Post by andyaber » Mon Oct 03, 2011 11:38 am
fnarr fnarr
Post by coxylaad » Mon Oct 03, 2011 11:41 am
he bends the pipes.
andyaber
Post by andyaber » Mon Oct 03, 2011 11:43 am
fnarr fnarr
SDN
Post by SDN » Mon Oct 03, 2011 12:23 pm
would be great if we could manage to achieve this within the forum at a reasonable price, especially if we have access to benders or even big benders, hopefully not wearing leather chaps!
Post by coxylaad » Mon Oct 03, 2011 12:34 pm
Mincehead wrote:Don`t see why not, can you use a TIG plant?
whats a tig plant?
SDN
Post by SDN » Mon Oct 03, 2011 1:08 pm
Tungsten inert Gas, basically you create an arc nbetween the tugsten tip and work in an inert gas shield and use a filler rod to weld. It is a sort of cross between Mig, and gas welding. Used extensively welding stainless and aluminium
Kenny
Post by Kenny » Mon Oct 03, 2011 1:40 pm
SDN wrote:Tungsten inert Gas, basically you create an arc nbetween the tugsten tip and work in an inert gas shield and use a filler rod to weld. It is a sort of cross between Mig, and gas welding. Used extensively welding stainless and aluminium
I use mine for these
drmac
Post by drmac » Mon Oct 03, 2011 6:43 pm
I would be interested in a 2 in to 1 system if the price is right . I was looking to make one over the winter and have made a parts list up from merlin motorsport.(mainly jetex exhaust parts) looking at about 120 quid worth of bends etc
They do a stainless y piece 44.5mm twin in to 50.8mm single outlet which should be spot on for the collector, i was looking at using stainless mandrel bends and fab the rest up from there.(i would tack it then get a good welder to finish it :D )
If we can get a good price i will hold off ordering the bits or if someone wants to make some 45mm headers it would save alot of work.
Steve
Post by HansJ » Mon Oct 03, 2011 8:24 pm
I might be interested to, 2-1-2 that is... Does someone do some calculating for getting the best performance, bends, lengths, tapering etc? Would it be too much to ask for allowing enough space also for YZF750 swingarm and possibly room for ajusting rear ride-height? The chain fouls my current system from MAB if i'm not 100 with chain tension, and that's with standard ride heigth.
Post by coxylaad » Mon Oct 03, 2011 9:08 pm
I know what Tig welding is, I have just not heard of a 'plant'
you mean welder?
Post by Mincehead » Mon Oct 03, 2011 10:02 pm
It`s a simple welders `term` for their equipment, `welding plant` is commonly used in engineering shops by welders. :wink:
