Handle bar grips?
Ritchiritch
Handle bar grips?
Post by Ritchiritch » Thu Nov 10, 2011 7:47 pm
Mine need replacing and just wondered is it a one size fits all job or are they a specific size ?
Re: Handle bar grips?
Post by Mincehead » Thu Nov 10, 2011 7:51 pm
Generic sizes in all honesty, although some American bikes, Harleys etc, use 25.4 mm (1") bars. Most bars are 22mm (7/8") on all other makes. :wink:
Foam grips or the older style ballon grips (bulge in the middle) tend to be my favoured choice.
meensy
Post by meensy » Thu Nov 10, 2011 8:05 pm
Renthal do different compound grips about £7 I think.
Barbancet
Post by Barbancet » Thu Nov 10, 2011 9:15 pm
Just out of curiosity, has anyone fitted heated grips?
I'm toying with the idea, but might just stick the horrible looking, but effective, Oxford Hothands on.
steve
steve
.....but what do I know? I'm not an Australian TMO.
Post by Mincehead » Thu Nov 10, 2011 9:23 pm
Plenty of members have them fitted, some are pretty good too and hardly look any different to any other grips. I recently saw some on a Harley that were adjustable by turning the bar end, very trick. :wink:
Barbancet
Post by Barbancet » Thu Nov 10, 2011 9:35 pm
Thanks, Mince.
I've got them on my Triumph , & they're a Godsend when the weather is like it was last Monday.
I'll give them a go.
Any preferences anyone?
steve
Post by Mincehead » Thu Nov 10, 2011 9:45 pm
A pal swears by these:
http://www.mandp.co.uk/productinfo/5838 ... ies/Tech-7
M&P list 5 types:
http://www.mandp.co.uk/productsList.asp ... ted%20grip
If you click on the blue text of each item then hovver your mouse over the images you can zoom in to them. I like M&P, great company and always good prices too. :wink:
Ooops forgot, for Ritchiritch:
http://www.mandp.co.uk/products/Bars-And-Footrests
Loads there to choose from. :wink:
jjmoto
Post by jjmoto » Thu Nov 10, 2011 10:06 pm
trx grips seem really short to me, i bought 125mm ones & had to cut about 5mm off the ends
Barbancet
Post by Barbancet » Fri Nov 11, 2011 12:36 pm
Mincehead wrote:A pal swears by these:
M&P list 5 types:
Thanks again.
I'll have a look.
s
steve
Barbancet
Post by Barbancet » Tue Nov 22, 2011 1:29 pm
I got the Oxford heated grips fitted on Saturday bought from http://www.racevisors.co.uk/category/ox ... rips-muffs for £74.99 including delivery. I was a bit concerned about finding a switched live & was going to tap into the brake light switch, but on looking under the seat, I found a brown wire with a cartridge fuse which had been snipped. I've know idea what it was attached to, but happily it turned out to be a switched live. :)
I hooked it all up & did a dry run before glueing the grips on.
Yesterday morning I had a moment of mild panic thinking that I hadn't checked it with lights/indicators etc working. I fired it up & checked everything. All was working & there was no smoke, so I suppose I must have got it right first time. :o
Result! Warm hands on arrival at work.
steve
