Hi all,
I am a fairly recent 1st time trx owner, having picked up a 2001 model relatively cheaply! After the cost of the bike I had a few hundred left (350 approx) to play with, so I thought I would let other people know what I did - which in my opinion transformed the bike.
Firstly it had blue spots and braided hoses, but brakes were still rubbish - so £100 went on r1 master cylinder which transformed brakes. yzf 750 dog bones to raise back - excellent mod (£25). £120 went on getting the carbs set up on the dyno which was well worth it. Another £40 on a new front sprocket minus one tooth, and plus three sprocket on the back - totally transforms gearing and accelaration. Proper mirrors that you can see behind you (£25), and a good old oil change with activx additive to coat the internals against excessive wear (bike has done 45k). That brought me upto £350 and a really sweet running trx.
When I next have some spare cash, I fancy some nice brembo front pads! I've also heard that a k&n air filter is a good mod - any opinions on this? Is there a better/cheaper way to modify air box, so it sucks in more air avoiding the flat spot around 3k in third?
Mods on a budget
- Killerwhale
Re: Mods on a budget
On a budget...well, it´s only good springs and correct oil setup in the fork left then!?beleza850 wrote:Hi all,
- M.V.
Some 'spot' calipers on the front will improve the front brakes even more.
I have a K&N filter in the standard airbox, but no flat spot at 3K rpm... might be related.beleza850 wrote: I've also heard that a k&n air filter is a good mod - any opinions on this? Is there a better/cheaper way to modify air box, so it sucks in more air avoiding the flat spot around 3k in third?
- B-art
Went the same route with my brake set up, Before investing in new pads get them first scrubbed in the the disks.
Next is indeed a spring/oil replacement/setup as this will transform the bike in to an even better handling one.
Finde a good suspension specialist for that.
B-art
B-art
jjmoto
Have the same set up, standard jetting, but with race cans also seems to smooth out power curveM.V. wrote: I have a K&N filter in the standard airbox, but no flat spot at 3K rpm... might be related.
Reason: fixed the quote for you ;-)
