R6 gold spot front calipers from 2003 will they fit??
Ritchiritch
Post by Ritchiritch » Tue Nov 15, 2011 11:54 pm
Will they fit my standard trx ? And are these as good as the blue spots a lot of you gus are using. Been offered some quite cheap ?
M.V.
Re: R6 gold spot front calipers from 2003 will they fit??
Post by M.V. » Wed Nov 16, 2011 12:01 am
Ritchiritch wrote:Will they fit my standard trx ? And are these as good as the blue spots a lot of you gus are using. Been offered some quite cheap ?
Yeah mate, as long as they're not the Radially mounted version (pretty sure the 2003 isn't) you'll be fine.
AFAIK, the blue, gold, silver etc are all the same, I have the golds, I went with gold because they suit my colour scheme.
I remember reading somewhere that the gold may be a stiffer caliper, but never heard anything concrete.
Post by Mincehead » Wed Nov 16, 2011 12:44 am
Yes lighter and somewhat more `rigid` too, the pistons are lighter and they are really the last stage in Yamaha`s brake fitments before the radial mounted calipers. :wink:
Wombat
Forum Marsupial
Post by Wombat » Wed Nov 16, 2011 4:41 am
Yeah, they're fine. I've got a set of '03 R6 Blue Spots on mine.
I think they've been on there since '05
No problems at all.
Post by Mincehead » Wed Nov 16, 2011 1:00 pm
Should that have read GOLD SPOTS Bob? :?
