Clutch return spring
Wombat
Forum Marsupial
Post by Wombat » Sat Jan 07, 2012 6:06 am
Notice the spring was broken yesterday.
Went down the wreckers this morning and got a replacement.
Took the circlip and washer off, removed the lever arm off the spline and replaced the spring.
Put it all back together, attached the cable but found that I was not getting very much adjustment from either end.
OF COURSE. read the Haynes manual and realised to get it right you have to push the lever arm either inwards or forwards to see if the two intendations line up.
OF COURSE they didn't, so it all came apart again and was adjusted so it was right. I just happen to have a spare brand new clutch cable that I'd had for ages, so put that on and was able to get some adjustment (the old cable was on it's way out anyway). The clutch is working now but the adjustment is nearly all the way out at the lever and at the adjustment point down on the frame.
The bike has done 95,000kms and its still the original clutch - I'm thinking that the plates are worn and therefore the loss of adjustment. Am I on the right track?
What's a good aftermarket set? EBC? Std or the Kevlar ones? What are other people using?
I'm gonna take it for a test ride tomorrow (around 25kms = to my daily commute) to see if its all ok. And will pop in at my mechanics on the way home on Monday and gauge his opinion - its only 500 - 1000km off its 96,000 k service so might get a new clutch fitted at the same time.
NWS870R
Re: Clutch return spring
Post by NWS870R » Sun Jan 08, 2012 2:35 am
Go with an OE Yam clutch - the fact that you got 95K from the original tells you all you need to know :wink:
Post by alextrx850 » Sun Jan 08, 2012 10:46 am
Changed the clutch in my first 75,000 kay motor..they looked about half worn..by comparison to the replacements.
No slippage..i just wanted to ..
but then im doing mostly highway work..
Post by Con Rod » Sun Jan 08, 2012 1:35 pm
presume you just need friction plates, Ferodo, ECB are both good
