R6 Rear shock: a few setup questions.
M.V.
Post by M.V. » Wed Jan 18, 2012 11:48 am
So, all of you knowledgeable lads & ladies, a few questions re the R6 rear shock: it was horrible at first, I adjusted for preload, then went standard settings as a start point.
Standard:
Rebound: 10 (min 3, hard, max 20, soft)
Fast Comp: 7 (min, 16, soft, max, 1, hard)
Slow comp: 15 (min, 24, soft, max, 1, hard)
So, then I tried this:
R: 9
FC: 9
SC: 13
Even worse. I think I went the wrong way on rebound damping, meant to back it off, but added more :oops:
Then I tried this
R: 5
FC: 5
SC: 10
Here, I finally figured out I was going the wrong way.
Now I've got this:
R: 12
FC: 5
SC: 10
Pretty happy with it, took it for a blast out in the country & everything seems to come together at about 160km/h, really nice.
Only thing I don't like is it's very jarring around town, so I want to remove some Slow Comp damping & some some rebound damping (I understand you should as little rebound damping as you can get away with)
Also, my preload is on the second last setting, Racetech calc recomends a 10.3kg/mm shock for the TRX & I think 10.5kg/mm for the R6 with my weight, so I guess 9.8 isn't too far off, I was going to replace the rear spring, but I think it'lll be ok...
So anyway, for the questions:
Do you think I'll get away with the stock spring?
Is my presumption about rebound damping correct?
If I remove some rebound damping, will it affect high speed? ie, will it still be as nice at 160km/h?
If I remove some Slow comp, will my bike squat too much under acceleration?
& will it still wheelie? :)
Thanks in advance.
:D
Re: R6 Rear shock: a few setup questions.
Post by phuk72 » Wed Jan 18, 2012 1:37 pm
what's your static sag?
Post by coxylaad » Wed Jan 18, 2012 1:37 pm
how heavy are you?
M.V.
Post by M.V. » Wed Jan 18, 2012 11:28 pm
coxylaad wrote:how heavy are you?
110kg with gear.
phuk72 wrote:what's your static sag?
Can't remember exact figure, but somewhere between 25mm-30mm-ish... More road than race.
Post by cobbadiggabuddyblooo » Thu Jan 19, 2012 6:14 am
R6 spring rate is for an 86 kg rider.. I have mine set on the second last setting when I'm two up with Janet on the back and she's 55kg.. I come in spot on at 86kg fully suited up... No wonder it's a bit harsh slower and quite stable at 160kph
M.V.
Post by M.V. » Thu Jan 19, 2012 6:37 am
So 140kg hey? Might back that off a bit :D Or get really fat...
That'll throw out my static sag settings though...
Post by phuk72 » Thu Jan 19, 2012 9:08 am
M.V. wrote:So 140kg hey? Might back that off a bit :D Or get really fat...
Have you done 'dynamic' sag measurements?
M.V.
Post by M.V. » Thu Jan 19, 2012 11:27 am
I've done free vs weight of bike & weight of bike vs me on bike, if that's what you mean...?
Post by coxylaad » Thu Jan 19, 2012 1:06 pm
are there any step by step guides kicking about that can be referenced for the set up of suspension?
Post by cobbadiggabuddyblooo » Thu Jan 19, 2012 2:08 pm
personally I have my spring set on the 4th setting and it's comfy for day to day riding but if I'm gunna have a little fun I just adjust it up one more and it suits my needs.
Post by phuk72 » Thu Jan 19, 2012 3:15 pm
that's right.
If all of those are in 'range' then the spring rates should be OK. Go back to standard settings and then change one thing at a time - and keep notes.
It's just a matter of time and trial and error
highlander
Post by highlander » Thu Jan 19, 2012 5:55 pm
coxylaad wrote:are there any step by step guides kicking about that can be referenced for the set up of suspension?
I found THIS LINK useful for a dummy such as myself
Projection Racing 2-1 with Akropovic hex carbon can, Keihin FCRs @ 150 main, R6 shock conversion, 520 chain conversion, Ignitech ignition, Li-po battery. Further weight reduction & front suspension in progress ....
Post by fung » Thu Jan 19, 2012 7:50 pm
do a search on our forum, coz i posted up links to video on youtube , R6 settings and pages for recording setting changes.
Kaylas bones help heaps with setup.
Fung
:rr:
Post by alextrx850 » Thu Jan 19, 2012 8:39 pm
Yep, Fung did a comprehensive set up and overall profile on the useage of the R6 rear shock ...about 6 months ago. =D>
Worth a search here...
Excalibre
Post by Excalibre » Sun Jan 22, 2012 1:35 am
M.V. wrote:So, all of you knowledgeable lads & ladies, a few questions re the R6 rear shock: it was horrible at first, I adjusted for preload, then went standard settings as a start point.
Standard:
R: 9
FC: 9
SC: 13
Then I tried this
R: 5
FC: 5
SC: 10
Now I've got this:
R: 12
FC: 5
SC: 10
Thanks in advance.
:D
I fitted a 2009 R6 shock recently and have been going through a bit of trial and error to set it up. The high speed compression is adjusted a bit differently and is done by turns rather than clicks.
I weigh in at 85kg.
My set up is for firm road use - most of my riding is 'spirited' runs through hilly country with a combination of tight corners and sweepers. I also do occasional track days.
My front end is set up with Racetech springs and Gold Valves with 32mm of sag.
My R6 shock is set up as follows:
Preload - second firmest setting = 31mm of sag (matches front sag). free sag is 7mm
Rebound - 12 clicks out from full hard
High Speed Compression - 2 1/2 turns out from full hard (maximimum of 4 turns, recommended setting is 3)
Low Speed Compression - 10 clicks out from fully hard
I'm sure there'll be some more tweaking but these settings seem pretty good to me.
Also, if it's jarring over bumps around town I suggest backing of the high speed compression a bit (not the low speed). Sorry if you already know this but the 'speed' relates to the speed that the spring is compressing - not the road speed. Therefore if it's jarring when hitting bumps it probably means the spring isn't able to compress quickly enough to absorb the shock.
