Air Filter Box - Won't stay on!
monkey79
Post by monkey79 » Mon Feb 20, 2012 12:18 pm
Hi guys,
Thank god for this resource. Just purchased a 97 with 37,000km (or so she reads ;) ) just like the one on the forum picture only not quite as tidy.
Anyway, it had some foam filters on it which I thought were giving some low rev power and stuttering issues (going off peoples comments on here). I tried to pop the old box back on but a) its a bugger to get down on the carbs (even with a little washing liquid) and b) it keeps popping off the flanges?!
Still getting the stuttering post 5000rpm on full throttle.
Has anyone had an issue with this, I thought it would be a nice fit (unless the bike is bent out of shape?!)
Dav
Re: Air Filter Box - Won't stay on!
Post by Dav » Mon Feb 20, 2012 12:30 pm
what carbies and where does this monkey live? welcome btw 8)
M.V.
Post by M.V. » Tue Feb 21, 2012 1:44 am
Welcome!
Are you doing them up too tight? Or too loose?
That would be my guess.
monkey79
Post by monkey79 » Sat Feb 25, 2012 3:31 am
Hey,
Sorry for the delay.
I'm in Sydney! A POM though :-)
Nope they're not too tight just a bad fit..they're the standard carbs.
There doesn't appear to be a lip or anything on the carb,.
Not a common issue then.....
Excalibre
Post by Excalibre » Sat Feb 25, 2012 11:52 am
Is the plastic sticky-out bit on the front of the airbox located correctly in the rubber grommet on the frame?
monkey79
Post by monkey79 » Mon Feb 27, 2012 12:23 pm
Yes,
not sure why it just keeps working itself off the tops and won't sit on the carb correctly. Obviously not a common fault then.... might try taking the trumpets out and checking their fitment etc.
highlander
Post by highlander » Wed Feb 29, 2012 11:11 pm
The rubber can deteriorate like on one TRX I bought ... give it a waft with heat gun, pop it down on the carb and fit a zip tie to make sure it's a good, closed fit. It should locate at the front on a lug IIRC, if it does then there's not much reason for it popping off again.
If you are still struggling you can tape some foam to the top of the airbox to help the tank keep it pressed in position.
Projection Racing 2-1 with Akropovic hex carbon can, Keihin FCRs @ 150 main, R6 shock conversion, 520 chain conversion, Ignitech ignition, Li-po battery. Further weight reduction & front suspension in progress ....
monkey79
Post by monkey79 » Thu Mar 01, 2012 8:46 pm
highlander wrote:The rubber can deteriorate like on one TRX I bought ... give it a waft with heat gun, pop it down on the carb and fit a zip tie to make sure it's a good, closed fit. It should locate at the front on a lug IIRC, if it does then there's not much reason for it popping off again.
Awesome! cheers for the tip. I'll check the heat option out. Thought it might have been the original foam being loose or something as well. Its in the lug but not sound so the foam option makes complete sense!
Just ordered a jet kit so I'll have her in pieces over the next week......
Cheers!
ssray
Post by ssray » Mon Mar 12, 2012 4:03 am
assuming the design is almost the same as a tdm, this is what i was advised to do.
remove the airbox,the tdm one splits in two,remove the carb to airbox trumpets and place in hot water, then attache to the carbs(mine wrer a bugger even with new hose clips) then fit the bottom half of the airbox over the trumpets then fit the top half of the airbox, should take 10 mins took me over an hour
Ray
