rear ride height
willieTRX
rear ride height
Post by willieTRX » Sat Feb 18, 2012 10:16 am
HI newbie on here bought got my trx about a month ago and its got a jack up kit on it and i want to put it back to standard what is the lenth of the standard links? cheers Willie
Re: rear ride height
Post by trixynut » Sat Feb 18, 2012 11:46 am
Firstly, welcome aboard!
Secondly, search is your friend.
Try searching something like 'standard dogbones' on here. Deffo be some pictures and measurements.
Most rear end jack-ups are done by changing the dogbone-shaped suspension linkages. Standard ones are shorter than jack-up ones (which usually come off a YZF750).
If you are after a standard pair, I have some I can sell/give you. I'd be interested in buying your jackup ones off you, or maybe just do a straight swap?
Post by Killerwhale » Sat Feb 18, 2012 1:19 pm
trixynut wrote:Firstly, welcome aboard!
Come on trix! [-X
Post by fung » Sat Feb 18, 2012 3:16 pm
longer bones LOWER the rear by raising the swingarm.
shorter bones RAISE the rear by lowering the swingarm.
:rr:
Post by trixynut » Sat Feb 18, 2012 3:21 pm
Yeah thats what i meant!
In my defense, i typed that on my mobile whilst on the bog, so my mind was elsewhere!!!
willieTRX
Post by willieTRX » Sun Feb 19, 2012 9:36 am
Cheers folks.Trix ill do a straight swap no probs ill send you a pm with my details if you do likewise ill get hem in the post tomorrow cheers
Kayla
Post by Kayla » Sun Feb 19, 2012 11:13 am
Standard are 182mm, centre-centre :D
Strix
Post by Strix » Sun Feb 19, 2012 12:48 pm
The YZF ones are a little bit to good at jacking up the rear. Does anyone have dogbones around 178 mm?
Just happy to cruise the TRX.
Kayla
Post by Kayla » Sun Feb 19, 2012 1:13 pm
Strix wrote:The YZF ones are a little bit to good at jacking up the rear. Does anyone have dogbones around 178 mm?
I do 179mm
http://www.projection-components.co.uk/ ... -152-p.asp
Strix
Post by Strix » Mon Feb 20, 2012 4:00 pm
Cool.
Anyone ho have tried lengths of dogbones (!) and have an opinion on whats the best middle road?
Today (with original ones) all is well but it rides a tad low and my boots touches ground before pegs (really hard tucked in).
Tried YZF-length dogbones and found it riding to high - no good center of gravity.
So somewhere in between should do it. Also have the 70 profile front tire so I have already lowered the front a bit but would like to get up the rear and follow with the front to gain some extra ride-height but keeping the handling at current level.
Opinions?
BR
Leo
Post by Mincehead » Mon Feb 20, 2012 5:25 pm
Errrr the original fitment front tyre is a 60 profile so you`ve actually raised the front by using a 70 profile.
It`s the tyre Aspect ratio, so 60 denotes 60% of the width of the tyre. In the case of the O.E TRX front tyre you are looking at 60% of the 120mm tyre width meaning the sidewall is 72mm high, your 70 profile will be 84mm. :wink:
A useful resource folks:
http://www.totalmotorcycle.com/photos/t ... reTech.htm
Strix
Post by Strix » Tue Feb 21, 2012 2:46 pm
Typo. I meant that since I have the 70 profile I lowered the front to accommodate for that, and because of that everything touches ground a bit earlier, since I at the same occasion lowered some extra mm for greater handling / quicker turn-in.
Next step would be to rasise the rear and follow up with the front, but only as much as is needed.
Hence my question - any experience among other riders of the TRX? Tried the YZF dogbones but found them too extreme for my style of riding.
Tanks for your kind answer and link Mincehead but as you understand I am aware of basic mechanics, not so good at building my message =)
:roll:
Kayla
Post by Kayla » Tue Feb 21, 2012 3:21 pm
Strix wrote:Typo. I meant that since I have the 70 profile I lowered the front to accommodate for that, and because of that everything touches ground a bit earlier, since I at the same occasion lowered some extra mm for greater handling / quicker turn-in.
:roll:
As a guide, I used a 120/70 on my bike (with the standard rear) with the rear end raised 20mm and the front dropped 20mm- it worked well :D
Strix
Post by Strix » Tue Feb 21, 2012 5:25 pm
What length of dogbones would give 15-20 mm raise at the rear? Can you do them? :D
Lowered 20 mm, as in measured from the top or 20 mm more (lower) than original?
Post by phuk72 » Tue Feb 21, 2012 5:54 pm
Strix wrote:What length of dogbones would give 15-20 mm raise at the rear? Can you do them? :D
That's prety much teh effect YZF dogbones have ;)
