Dav
by Dav » Tue Feb 28, 2012 7:52 am
I chucked a sickie today and got the keihins successfully installed on the bike. Good lord almighty...what a difference!
Thanks to the peeps who encouraged me to persevere past a) my first unsuccessful install attempt (I just bolted them on without checking settings...didn't work out, put on the Mikunis) and b) unsuccessful mechanic install attempt ($900 later...mikunis with dynojet, keihins in a box).
All I did was get everything in spec and install...ramair and stacks. Needs some dialling in off idle and the tacho does the dance every 10 mins or so but otherwise awesome...broke traction in 3rd after getting a partial refund from the mechanic
by trixynut » Tue Feb 28, 2012 9:14 am
All sounds good!
If your FCRs havent got TPS connection, you can bypass it by doing the TPS modification. This will stop the tacho dancing.
If you have a tps connection, sounds like it just needs some adjusting.
Dav
by Dav » Tue Feb 28, 2012 9:18 am
Tanks Trix...I have the mod bookmarked, I think it just needs a little tweak
Kayla
by Kayla » Wed Feb 29, 2012 10:22 am
FCRs rock!
I don't have the right words to describe how utterly crap the standard ones are in comparison and how asthmatic they make the engine
by fung » Wed Feb 29, 2012 10:28 am
What !! So now i have to save up a grand or so to join the 'boys' (and Kayla)
luckily, mine goes pretty good so i will just have to spend money on the TDM (power commander is next
by alextrx850 » Wed Feb 29, 2012 10:53 am
Kayla wrote:FCRs rock!
With the aussie dollar being strong at the moment..it would seem a good time to buy a nice carb upgrade...
only thing is that the guys here that have them dont seem to get away from me....mine arnt normally jetted either...niether is the air box ,,or the pipes...
Dav
by Dav » Wed Feb 29, 2012 11:51 am
True Alex, it ain't the size of the dog in the fight but the size of the fight in the dog etc
That said...I am genuinely amazed at the power hike....night and day against stock...and that rattle and hum/induction transition sequence is pure rock and roll
by cobbadiggabuddyblooo » Wed Feb 29, 2012 3:38 pm
the difference is we just don't have to try as hard
you may just have to use the gearbox a little more
by alextrx850 » Wed Feb 29, 2012 8:00 pm
kayla,dav and even cobbas words show sense...its a case of not knowing until haveing...
needles and emulsion jets are coming up for replacement soon too...will convert and go the whole way.
M.V.
by M.V. » Wed Feb 29, 2012 11:33 pm
Great news mate, glad you've got it sorted!
What was the problem in the end?
Excalibre
by Excalibre » Wed Feb 29, 2012 11:45 pm
Dav wrote:...and that rattle and hum/induction transition sequence is pure rock and roll
I know what you mean! I'm running mine with the airbox at the moment while I decide on what cobination of velocity stacks and filter I'm going to use. But I did run it with the velocity stacks (and mesh filters) in the shed when I first installed the FCR's and I'm addicted to the sound! I didn't think it was possible for a beast to roar, whistle and hiss all at the same time
Dav
by Dav » Thu Mar 01, 2012 1:43 pm
M.V. wrote:Great news mate, glad you've got it sorted!
It would appear the settings weren't per spec from the factory and the mechanic didn't check them like I asked. Actually, I'm being kind to the mechanic...all I found were the floats were 8mm instead of 9mm...I set both sides to 9mm and reset what the mechanic did (fuel 4 turns out instead of 1 in an attempt to get it to idle). The problem appears to be the mechanic.
