Braking mods
- Stankflapper
Re: Braking mods
yes ^^^that in fact started life with a pair of dusters
Heldenkeks
Re: Braking mods
I combined my blue spot calipers with a R6 (RJ15) radial m/c utilizing ABM Peak front discs with AP Racing sinter pads.
It couldn't get any better
wooooooha
- M.V.
Re: Braking mods
Thanks for the info, good to hear from someone who's done it.Heldenkeks wrote:I combined my blue spot calipers with a R6 (RJ15) radial m/c utilizing ABM Peak front discs with AP Racing sinter pads.
It couldn't get any betterwooooooha
Re: Braking mods
Bear in mind M.V. Those ABM discs will likely be `grippier` than the TRX discs, it`ll be about the materials used in their manufacture.
You`ve got to go some way to beat cast iron discs but folk don`t like the rusting so it`s used less these days.
My Guzzi discs would be orange if she was out in the rain more than a few hours but within a couple of braking applications it was all removed from the braking surface again.
Saying that I did use a suitably sized drill bit in a hand brace every month or so to clear the holes in the discs as the rust and pad compound residues would start to close them up.
- M.V.
Re: Braking mods
I've got Galfer Wave Rotors which I presume are steel (not stainless, cos they rust in the rain
), my stock rotors are well past dead!
I presume the Galfers should be a similar thing to the ABM/other AM stuff...
- Stu99
Re: Braking mods
X2, couldn't agree more. That's why I bought mine from an official Brembo distributor, not on-line.phuk72 wrote:Just be very wary about buying from anywhere other than approved dealers - there are lots of moody copies that are potentialy dangerous (as in life threatening!)Stu99 wrote:Or have power and feel plus good looks to boot
Had to empty my wallet some, but definitely some of the best $$$ spent on my bike in my humble opinion.
And also why it emptied my wallet so
Heldenkeks
Re: Braking mods
I started with Blue Spots / OEM Disks / 14 mm Axial (already good performance) then mounted the ABM disks (increased "grippiness") and finally switched to the Radial 16 mm which again improved performance and pressure control at the lever. To my mind the easiest way towards a "OEM parts - two finger brake"M.V. wrote:Thanks for the info, good to hear from someone who's done it.
- phuk72
Re: Braking mods
The Galfers have got a very high iron content which is why you will see surface rust. They are imho the best aftermarket daily use discs availableM.V. wrote:I've got Galfer Wave Rotors which I presume are steel (not stainless, cos they rust in the rain), my stock rotors are well past dead!
- M.V.
Re: Braking mods
That's good to know Phuk, I don't really know much about them, apart from they came up for sale at a great price right when I needed new discsphuk72 wrote:The Galfers have got a very high iron content which is why you will see surface rust. They are imho the best aftermarket daily use discs availableM.V. wrote:I've got Galfer Wave Rotors which I presume are steel (not stainless, cos they rust in the rain), my stock rotors are well past dead!
