Changes through the years?
- Rural Rat
I am interested in any changes that were made to these bikes through the few years of production. Particularly interested in Australia spec models. Mine is a '99 (Blue) and I am about to start a light resto, it does not need much work at all but I want to keep it as original as possible.
- M.V.
Re: Changes through the years?
I don't think there was any... Part numbers of the valves would be changed from the first model, but that's it...
May be wrong though.
- phuk72
Fundamentally there were no changes to the models through the years although minor variations do exist - nothing to worry about though as everything is interchangeable
- Rural Rat
Cheers guys. I thought as much. I did have a black '96 model originally and it did all appear the same thought it worth asking.
- trixynut
Yep, as has been said, ignoring early Japanese import '95 models, only changes are colours.
- Wombat
- Forum Marsupial
One of the few minor changes was the way of mounting the rear indicators.
Early ones like mine mounted straight to the plastic whereas the later ones mounted to a small metal plate.
- cal
Is there not some difference with Aussie lights switches being pemanantly on?
Think it is to do with the switchgear
Cal
- Wombat
- Forum Marsupial
Yeah, but there is a tiny little cover on the switchgear where the on/off light switch goes on the overseas models
- Con Rod
was there a change in the tail-piece from a one piece to a 3 peice set up?
- phuk72
Not that I am aware of. In my time I owned a 1995 import (one of the first ones made) and that definitely had a 3 piece rear.Con Rod wrote:was there a change in the tail-piece from a one piece to a 3 peice set up?
There are aftermarket one piece tail sections, I actually have one a single seat version, but they do twin seat versions too.
BigAl-TC
If that metal plate steps out approx 8mm and is offset down about the same it is most likely part of the Ventura Rack Fitting Kit.Wombat wrote:One of the few minor changes was the way of mounting the rear indicators.
Alan.
Alan.
- Dav
Ummm...the post 96 ones didn't hemorrhage oil
- Con Rod
hmm well there ya go, guess mine is after market so
- Rural Rat
Anyone had any dealings with these guys?
http://www.oemmotorparts.com/oem3.asp?M ... X%20%20850
Seems ridiculous to me that parts can be sourced and shipped from so far away at a fraction of local dealer prices. Even after my loyal customer discount.
