Excessive Tinking on Cooldown
Re: Excessive Tinking on Cooldown
Post by Mincehead » Fri Apr 20, 2012 6:40 pm
I would START at 170 mains and work down, I reckon I`m going to find 165`s to be just about right and it`s what I`ll be aiming to use after mine is back together and dyno checked.
Dav
Post by Dav » Sat Apr 21, 2012 12:33 am
Thanks for your input guys. My bike has staintune exhausts, standard headers. Whether running a ramair filter or the airbox (snorkel on, no holes, K and N filter) power and running have seemed great over 4000 rpm, even shutting the throttle and slamming it back on give a huge shove when the bike is on the move...no problems holding a steady throttle, no popping on decel....just getting off the line fuelling is poor.
Yer right Cobbs...lower down it's a balancing act for sure :lol:
NWS870R
Post by NWS870R » Sat Apr 21, 2012 1:00 am
@ Mince - 165 mains, 2 notches richer than they come out the box should work for you as long as you're not running stock airbox (which i'm pretty sure you're not :wink: )
Dav - you're not running the TPS mod are you? This would explain the lack of low end power?
bagmaker
Post by bagmaker » Sat Apr 21, 2012 1:29 am
hi Dav
have you gone over all the bolts on the exhaust?
unless the tenp gauge reads high i woulnt worry about tinking noises
those who can count
and those who cannot
Dav
Post by Dav » Sat Apr 21, 2012 1:51 am
The tps is on and set...though once in a while (after the bike warms up) the tacho dance begins. Maybe it is secretly on full advance after all :wink:
Will do that bagster...and you are proably right. I expect that being hypersensitive to any fuelling issues has made me hypersensitive to any odd noise coming from the bike :lol:
Post by Killerwhale » Sat Apr 21, 2012 5:57 am
Dav wrote:Thanks for your input guys. My bike has staintune exhausts, standard headers. Whether running a ramair filter or the airbox (snorkel on, no holes, K and N filter) power and running have seemed great over 4000 rpm, even shutting the throttle and slamming it back on give a huge shove when the bike is on the move...no problems holding a steady throttle, no popping on decel....just getting off the line fuelling is poor.
Just a stoooopid question, have you tried another trix with flatties? You really need to use the throttle in another way than standard carbs. I have a dyno from Yamaha (they had a free dyno day) and although i told them i had flats he slammed the throttle and then said they where installed wrong :lol:
Dav
Post by Dav » Sat Apr 21, 2012 6:36 am
Killerwhale wrote: Just a stoooopid question, have you tried another trix with flatties? You really need to use the throttle in another way than standard carbs. I have a dyno from Yamaha (they had a free dyno day) and although i told them i had flats he slammed the throttle and then said they where installed wrong :lol:
No, I haven't tried one with flatties...I might jump on a plane and head over to your place :lol: I'll take a peek at the plugs tomorrow (stuck at work now)
Post by cobbadiggabuddyblooo » Sat Apr 21, 2012 9:05 am
I just pulled the carbs off and they still have the stock 150 jets inplace and I'll scan the dyno report for ya. It actually has them with 1 clip leaner with the and the fuel/air reading will confirm this around 4000rpm...Thats with the bellmouths and largebore 2 into 1
Dav
Post by Dav » Sat Apr 21, 2012 9:30 am
Success! \:D/ I had a long dinner break so ripped home, checked the plugs (thanks forum for the tip to swing the radiator away) and sho nuff they were sooty after just 2 days on the bike. I thought there's no point in mucking around, backed the air screws out another full turn and we have a winner! Clean fuelling off idle right thru the range...happy happy day! :headbang: :headbang:
The tacho still does the dance after 10 or so mins but that's a minor issue compared to the saga of the flatslides. Thanks all for your help 8)
Post by Killerwhale » Sat Apr 21, 2012 9:35 am
=D>
Post by cobbadiggabuddyblooo » Sat Apr 21, 2012 11:11 am
Here we go 150 mains running bellmouths and when I get my verniers back from mums place I'll measure the pipes on the exhaust to give you an idea and post a pic of the exhaust
There are three readings on most one when the bike first arrived, another after camchain replacement/service and moving needle with teastrainer fitted in exhaust and the other with the restrictor inplace
Last edited by cobbadiggabuddyblooo on Sat Apr 21, 2012 2:30 pm, edited 1 time in total.
Dav
Post by Dav » Sat Apr 21, 2012 1:58 pm
Brilliant idea...use teastrainers for more power and a nice cuppa after the ride :D
Post by Mincehead » Sat Apr 21, 2012 2:13 pm
Errrm I think the max figure (red curve) is with the strainers removed is it not?
Post by cobbadiggabuddyblooo » Sat Apr 21, 2012 2:14 pm
yer talk about GREEN TEA use your carbon points to boil it :lol: :lol:
Post by cobbadiggabuddyblooo » Sat Apr 21, 2012 2:15 pm
just one strainer..its a 2 into 1
