Cheap Digital Speedo/Tacho?
n8balls
Hey riders, has anyone got experience with these cheap digital speedo/tacho/fuel gauges? They look like copies of more expensive ones
http://www.dan-moto.com/lcd-digital-spe ... 826hle9ag0
My question is more about universal digital gauges rather than this particular unit:
1. I understand that for the speedo, you put a magnetic pick up on your front wheel and input the diameter but, is the tacho input compatible with the TRX motor’s tacho output?
2. Also can the TRX fuel gauge output interface ok with a unit like this?
Cheers, N8
Cheers, N8
Re: Cheap Digital Speedo/Tacho?
The round version is a Chinese copy of a much more expensive Acewell unit, blatant copy too I might add.
- thch
Hi there.
Go for a Koso RX2N. Bought mine from the UK for approx. £180.
Super easy to install and has a _lot_ of features. Fits nicely besides the Garmin gps instead of the original instruments,
Only thing missing is the fuel gauge, but I suppose you'll have to fit a TDM tank to get that feature. I'm using the gps fuel gauge instead.
I'll take some pictures if you want....
Regards Thomas, Denmark.
- rbaron25
Hi thch,
Would love to see some pics of your gps/speedo setup and how you fixed it/ put it together...
I didn't see you...
Cause you didn't bloody look!
- thch
Finally I got some pictures of my Koso/Garmin setup.....
They are a sweet unit....gives plenty of room too...oh and your check engine light is on..
ive gotten pretty used to the digital speedo on my little acewell...like it a lot...yours is the coolest collective upgrade ive noticed so far.
- thch
Hi alextrx850.
You noticed the engine light.
That is actually the only indicator I can't make any use for - all the rest is working (oil/water temp, oil pressure, high speed warning, turn signals, neutral, high beam, gear shift warning)
What fun stuff can I make to use this indicator?
- M.V.
Edit; already covered
