Need some advice - Manual says Synthetic, can you use Part Synthetic? If so what do you recommend.
Synthetic or Part Synthetic ?????
- Steelback
Hi Guys
- Silver
Re: Synthetic or Part Synthetic ?????
Motul 5100 10/40 in the TRX. Started using Halfrauds semi in the TDM as it drinks oil. Its £23 for 5 literes against Motul at £30 for 4 litres.
I have used the motul in the TRX for about 6 years 25K miles.
Dave
Dave
- Steelback
Cheers for the advice Dave
- phuk72
Hein Gericke semi synth - £13 for 4 litres
Use it in all my bikes (except the 2T obviously!)
- Steelback
- Silver
Me too, once i use the 5 litres of Halfords in the TDM (which wont take long) does about .4litre in 300miles.
Dave
Dave
- trixynut
Second (or third) that advice above: I use a 'cheaper' semi-synth and change it a bit more regulary.
Synth can cause a bit of slip.
Semi synth 10W/40 Halfords too, even cheaper in my case as I have a trade card.
The TRX really doesn`t need nor require anything better as long as you change it before the recommended milage covered, I do mine at 3000 mls.
I know folk have found fully synthetic better in helping to cure oil usage but mines a good-un uses hardly any.
- pwmotorsports
have used fully clutch slips bad with it so stuck to semi and change it every 1-2k on all my bikes along with the filter, the way i look at it is its a cheap option that can only give me less chance of spending lots on a big repair
- Luvie1953
Hi guys,
I've used 20w/50 fully synthetic, not cheap, but it's made a noticeable difference to engine noise, there was a definite 'clicking' before that has now gone!
No evidence of clutch slip either, which some have reported.
1999 TRX 850, blue, R6 blue spots, Dynojet jets, Ignitech ignition module, K&N air filter, Remus Carbon Fibre Grand Prix cans, belly pan, single seat cover, hugger.
20W / 50 is a tad heavy for cold winter work, but if the bike`s only used in the UK`s `warmer` weather you`ll not have any issues.
10W / 40 gets around the motor easier at start up, I`ve seen it in print that more than 75% of engine wear occurs at start up, when tolerances are at their greatest and oil is finding it`s way through the galleries and drillings.
- Luvie1953
I'm now a confirmed 'fair weather' rider
I've got to the stage in my life where I've done all the rain/snow/ice riding I'll ever need!
So Trixie only comes out to play on nice days, I've also used Activ8 oil additive - to help on cold starts! It does seem to do what it says on the bottle... I've used it in the car as well (a high mileage BMW)
Activ8? Yes, we`ve another member here who swears by it too, I might try it myself one of these days.
- Luvie1953
It does seem to work, and it's suitable for use on bikes with wet clutches!
