Tilting Up Gas Tank?
throttle
Post by throttle » Thu Dec 28, 2006 9:26 am
As I was putting some taller bars on my TRX today, I got to the point where I needed to re-route the throttle cables. I removed the front tank bolts and the tank tilted up about 15 degrees before the hose between the petcock and the pump ended the fun.
How do you guys stop gas from leaking everywhere when you want to tilt the tank back? Or do I need to empty the tank prior to servicing the bike?
I thought of this picture when I was trying to tilt the tank, but now I can see that the fuel lines are disconnected.
[quote=]
[/quote]
cheesie
Post by cheesie » Thu Dec 28, 2006 11:23 am
if you take of hosses they will not leak, or the should,nt only a little amount that is in the hose will come out
Post by phuk72 » Sat Dec 30, 2006 12:49 pm
Wot he said ^^^^^
Or you could fit longer fuel and breather hoses so that the tank can be flipped back without disconnecting anything
