DIY 520 Conversion
Re: DIY 520 Conversion
2006 to 2008 R6 drive sprockets fit, I know because I had a 15 tooth varient in 525 on my TRX for a while.
You`ll definately get those in a 520 as they`re so commonly raced.
- M.V.
I went back & did some more research, the JT sprocket for the TRX is listed for the R6 as well, some models only though, namely 06-12.Mincehead wrote:2006 to 2008 R6 drive sprockets fit, I know because I had a 15 tooth varient in 525 on my TRX for a while.
http://www.jtsprockets.com/catalogue/sprocket/JTF1586
So I think the one I've ordered should work, it's Driven sprocket in 520. Still waiting for it to turn up though...
Thansk Italian Red, always good to have a few options.Italian Red wrote: errata corrige:
sorry is not a kawa sprocket but a Suzuki GSXR 1000 k7-k8 one
Afam code 28402-17
Pics will be posted asap
- Italian Red
here the sprockets (the Gixxer one is the right one )
the Afam sprocket on the shaft
the sprocket i've tried is a R6 1999 version. Mincehead is right, sorry for my bad tip.
- M.V.
Fantastic, thanks very much Italian Red!
- Italian Red
You are welcomeM.V. wrote:Fantastic, thanks very much Italian Red!
- M.V.
The front sprocket turned up, very nice.
However, to get to this, there's a few caveats.
The old sprocket:
The new sprocket. It's a bad photo, but you can see a gap, the new sprocket offset is a little off.
The old sprocket:
- M.V.
How much of a gap? Well, my verniers are broken, so I can't tell you exactly, but it's about the thickness of the locking washer used on the front
So, washer on the front, washer on the back & we're good to go. I'm not sure it will make that much of a difference, but I guess it can't hurt... Not sure if it's all the R6 sprockets that are like that or just this one.
Seems alright.
Flipped the rear sprocket, the holes are slightly larger than the TRX sprocket, but not an issue.
Seems alright.
- M.V.
Apparently the rear is a 45T, not a 43
Which leaves me with this:
Which is where I stopped for the night. Not sure if I have enough adjustment to make this work, but I'm usually supposed by how little it takes to take up the slack.
So: 520 conversion, check.
You need: everything in the original post, plus a spare locking washer to space the spocket
- fung
I spy a drain tray with a paintbrush in the background
A good time to give that area a good scrub eh
- M.V.
Get stuffed.fung wrote:I spy a drain tray with a paintbrush in the background
It's as clean as it's going to get, until I strip it down & repaint it next year. After that I'll take some pride in keeping it clean.
- M.V.
Well, my chain is rooted! But three or so years out of that one, pretty happy with.
Have ordered a new chain, same again, only $85 this time, rear sprocket looks fine, but I think I'll order a new front just to be on the safe side.
phil108
Cheers for all this info guys, one of my next jobs!
goose202
Discovered this thread when looking for options on the more expensive 525 chains - good info, thanks.
Looks like front sprockets are easy enough, but it looks like the NX650 rears don't come smaller than 43 teeth? Was hoping to keep my 16/39 or perhaps 17/41 gearing. Anyone have any other rear sprocket hints?
nr
JT do an NX650 from 42-47T: http://www.jtsprockets.com/catalogue/sprocket/JTR245_3goose202 wrote: Looks like front sprockets are easy enough, but it looks like the NX650 rears don't come smaller than 43 teeth? Was hoping to keep my 16/39 or perhaps 17/41 gearing. Anyone have any other rear sprocket hints?
Which admittedly doesn't help in your search for a 41 tooth, but it's closer.
Trixed
Hey MV,
My chains is close to dumping, am keen for the same conversion. To Clarify can u please confirm as below:
Front Sprocket and spacer:
Rear Sprocket:
Any spacers or bolts or things I may need to install.
How the conversion going now that you have used it a fair bit?
Rear Sprocket:
M.V. wrote:Apparently the rear is a 45T, not a 43![]()
