So who needs Darrell Lea when you have Kayla !
M.V.
Re: So who needs Darrell Lea when you have Kayla !
Post by M.V. » Tue Aug 07, 2012 5:29 am
Tasty!
Those exhaust hangers look thicker than the ones I got, if that's the case, very good.
Kayla
Post by Kayla » Tue Aug 07, 2012 11:05 am
M.V. wrote:Tasty!
They are, we've gone to 4mm ally for the hangers now.
M.V.
Post by M.V. » Wed Aug 08, 2012 12:12 am
Good to know, thanks Kayla.
Post by Con Rod » Wed Aug 08, 2012 4:14 am
Fung, and you installing the rear set plates on a road or a track bike? And if on a road bike what are you doing with the rear brake switch?
Post by Mincehead » Wed Aug 08, 2012 7:03 am
Inline hydraulic switch from the banjo bolt, that`s the way to go, neater too. Like this one: :wink:
http://www.lustracing.co.uk/rearsets/ya ... -switch.ht
Post by fung » Wed Aug 08, 2012 8:42 am
Con Rod wrote:Fung, and you installing the rear set plates on a road or a track bike? And if on a road bike what are you doing with the rear brake switch?
Hi 'Con' ;)
i already have these on my road TRX and the new set will go on the "trackie".
The beauty of these little gems, is that the OEM assemblies bolt on as is with no need for aftermarket switches.
you need to purchase 2 bolts to mount the plates to the OEM gear and the original bolts mount the lot to the bike.
:rr:
Red Rex
Post by Red Rex » Wed Aug 08, 2012 7:30 pm
@ Kayla
How much for a pair of the 4mm exhaust hangers Including P&P please ??
