spanner
by spanner » Sat Sep 15, 2012 5:33 pm
hi all
removed my front wheel as i suspected the front bearings were worn, with the wheel removed there was alot of play in the spindle, so ive removed the bearings and got some new ones but there just the same
. both bearings new and old are slack on the
spindle, so its the wrong bearings wrong spindle or just me being ocd
by trixynut » Sat Sep 15, 2012 7:41 pm
If u ordered new bearings using the code from the old ones which were loose, sounds like it had the wrong ones in.
Cant be spindle else wouldnt fit thro spacers, fork bottom, speedo drive etc.
What do you call excess play anyway?
Search on here for bearing numbers otherwise I have an old set I can check the numbers on tomorrow.
spanner
by spanner » Sat Sep 15, 2012 10:31 pm
hi trixynut
the code on the bearing is 6203-2rsh/c3 13b 03115 j 54f italy, i orderd them from ebay for a trx but they are
exactly the same as the ones that were in and both have alot of play on the spindle about 2-3 mm side play.
by trixynut » Sat Sep 15, 2012 10:46 pm
There shouldnt be any play on the bearings at all.
Theres a thread on here with all bearing numbers if you search.
Copying and pasting the bit on front wheels, its:
Front Wheel……..93306-20314………..…Deep-groove Ball……….17 40 12………6203 (2RS)……………..........2
Will check my old set when I can.
spanner
by spanner » Sat Sep 15, 2012 11:22 pm
cheers trixynut
ive just been doing a bit of searching and the bearing i have are used for trailors or landrover pulleys
C2 = Clearance less than normal
C3 = Clearance greater than normal
C4 = Clearance greater than C3
spanner on Sun Sep 16, 2012 4:38 pm, edited 1 time in total.
by Con Rod » Sat Sep 15, 2012 11:44 pm
spanner
by spanner » Sat Sep 15, 2012 11:54 pm
thanks conrod
i was just looking at wemoto ....
lenny
by lenny » Sun Sep 16, 2012 9:11 am
The c rating of bearings refers to the internal (ball to race) clearance for different applications eg. crankshaft bearings require slightly bigger clearance to allow for crankshaft flex and is measured in microns not 2-3mm. Nothing to do with your problem.
spanner
by spanner » Sun Sep 16, 2012 3:12 pm
thanks lenny
found a page on c ratings hmm interesting stuff ,
the bearings have 2-3 mm play
when there on the spindle or the spindle has 2-3 mm (4-6 total) play when its in the wheel just seems odd.
ive done a search with the correct size and as far as i can see i have the correct size but c3 rated
by trixynut » Sun Sep 16, 2012 6:02 pm
Checked the bearings I just took out and they are:
SKF 6203 - 2RS N/C3
Kayla
by Kayla » Mon Sep 17, 2012 9:49 am
spanner wrote:thanks lenny
What size spindle is in your bike? Can you put a picture of the forks up here?
by Con Rod » Mon Sep 17, 2012 1:45 pm
trixynut wrote:Checked the bearings I just took out and they are:
SKF 6203 - 2RS N/C3
you doubted my table?
seriously though, I tripple checked that table before I posted it up and brought that specific excel sheet to the bearing shop to order all of the bearings for my bike......every bearing number and size listed in that table has been fitted to my TRX
spanner
by spanner » Mon Sep 17, 2012 3:46 pm
ive measured the spindle with a vernier gauge and it measures 16.5 mm with the bearings being 17 mm i am sure the spindle should be a bit
larger, i have the correct bearings so ive orderd another spindle
. hope fully that will cure my head shake.
by trixynut » Mon Sep 17, 2012 8:04 pm
Ordered one?
Hopefully not paid new yamaha price?
I have two spare ones in the shed....
spanner
by spanner » Mon Sep 17, 2012 10:19 pm
dam i was going to ask if anyone had a spindle, got one from fleebay for 20 qwid i hope
that cures it, need to do a bit more riding before winter.
