K&N in standard airbox
cheesie
put a k&n in the air box today took it for a wee burn as it was dry,this was the first decent blast I have had on it, but on the way back I noticed when sat at traffic lights when I blipped the throttle it died, this only happend once it was warmed up could it be running to rich now plus it only happend from a closed throttle what do you think
- Killerwhale
Re: K&N in standard airbox
When my bike felt like it just died on full throttle it was WAY lean, i figure you should get "bang bang coff coff" if rich.cheesie wrote:put a k&n in the air box today took it for a wee burn as it was dry,this was the first decent blast I have had on it, but on the way back I noticed when sat at traffic lights when I blipped the throttle it died, this only happend once it was warmed up could it be running to rich now plus it only happend from a closed throttle what do you think
....and you´ve actually leaned it by putting on a K&N...
Tourqe-a-holic
- phuk72
Presume you mean since you put the K&N in and that it was OK with the standard filter?this was the first decent blast I have had on it
The K&N is a free flowing filter (over the standard one) and as such this will lean the mixture slightly over standard. That said, TRX is jetted slightly rich as standard and the K&N will not affect the jetting that much.
My guess is that the filter change is a red herring
Go back and check you put everything back together again properly. Need to ensure filter is in correctly, airbox is sealed to carbs correctly (you may have knocked them off when changing the filter), fuel is turned on and pipe not kinked and most importantly (this is where my money is), check the vacuum pipe is connected to the fuel cock and that it is not kinked.
- honkdawillydahonk
cheesie
had a check around all the hoses and everything looks fine, no kinks took it out again same thing happend only when it is well warmed up so I have put standard filter back in and if it is dry tomorrow will give it another shot, strange it only happens when engine is hot
it seemed to rev cleaner with the standard filter in but bike was sitting maybe 20 minutes I also tried the hose clamps on the carbs although I was able to get another turn or so on them they wernt loose
cheesie
brand new filter pre oiled. I was thinking it might need re jetted but I dont want to start spending money on dyno jet kits by the time you fit one and have it properly set up on a dyno it will run into £100-£200
I might get away with lifting the needles and fitting a bigger main jet
I am still hoping to pick up a set of flat slides for the right money
- slow codger
cheesie
lifted the needles a notch, the last groove my mate had some 144 main jets left of a dyno jet kit so I fitted them, bike now runs fine, although it does not surge at constant throttle openings and pulls clean enough from 40mph in tyop gear it will snatch a little from a closed throttle around town which says to me she is now running a little rich will have to put it on a dyno for a proper gas analysiss to make sure all is fine
