Who knows which swingarm is being used on my TRX?
Sly
Post by Sly » Sat Nov 24, 2012 10:39 pm
Hey,
I recently bought a TRX from 1996, with a 190 rear tyre on it. I am planning to rebuild it a little bit. It has an upgraded swingarm, but the former owner did not know from which alternative bike it came. It does not look like a YZF 750 or Thunderace swing arm.
Who has experience in this and knows which swingarm is normally being used for a 190 rear tyre?
KR
Silvester
Re: Who knows which swingarm is being used on my TRX?
Post by Con Rod » Sat Nov 24, 2012 11:09 pm
Looks like a standard TRX850 one painted black
Post by Mincehead » Sat Nov 24, 2012 11:47 pm
+1 Totally stock arm painted black.
Post by alextrx850 » Sun Nov 25, 2012 1:19 am
if your wheel has a [17xmt 5.50 dot] number on the left of the wheel- spoke closest to the valve...it will be a yzf 750..- five and a half inch rim wide capable of having a 190 hoop....look to see if you have that..otherwise, you have a standard trx five inch rim fitted with a car tyre...you should have a 160 tyre.
Post by cobbadiggabuddyblooo » Sun Nov 25, 2012 2:45 am
std tyre they came out with is a 160..you can actually fit upto a 180 on the std rim...
Post by trixynut » Sun Nov 25, 2012 12:58 pm
+2 bog standard painted.
Post by phuk72 » Mon Nov 26, 2012 9:10 am
Yep - standard swing arm with what looks like a YZF750 wheel
Sly
Post by Sly » Sat Dec 01, 2012 10:06 pm
Thank you all!
I thought a 190 would not fit in a standard swingarm, but checking the swingarm it indeed looks quite like a standard swingarm, haha!
Silvester
