Front wheel bearings
Re: Front wheel bearings
Post by Mincehead » Wed Dec 12, 2012 9:21 pm
Hahahahah, yes I think anyone with an air gun might have done that Alex, I know I have.
Now H&S sanitisers have ruled that air guns must have a multi `holed` nozzle to stop air being blasted through skin they don`t tend to have the same power sadly.
I have a tame garage owner who doesn`t have those compromised air gun nozzles. :wink: :lol:
Post by davamb » Mon Dec 17, 2012 4:59 am
New front bearings and seals bought today - $32 the lot from local bearing shop. Just have to put the Norton front end back together so I can get it off the stands and out of the shed to make room for the TRX.
Post by davamb » Mon Dec 24, 2012 1:18 pm
Bearings and seals replaced today. One bearing totally knackered. The speedo drive was full of a grey gunk - a mayonnaise of grease and water and it was the bearing on that side that was buggered.
Note that the front only takes 1-off 23-40-7 seal, the side away from the speedo gear. The speedo gear side takes a 45-56-7 seal. I was lucky in being able to get the larger seal today; my local supplier Hallam Bearings are good guys.
Post by cobbadiggabuddyblooo » Mon Dec 24, 2012 3:33 pm
$15 for the pair posted to your door online from pyramid for the TRX they have rear kits for the same price.. As Zednine said basically a bearing is a bearing is a bearing just how much mark up they want to charge you :wink:
Post by cobbadiggabuddyblooo » Tue Dec 25, 2012 7:25 am
Just checked $11.50 plus $4.50 postage for front wheel bearing kit for those with yzf front end also :wink:
