tzx660s TRX bike rebuild
Post by dixonj » Sat Jan 05, 2013 8:21 pm
Hi all, tzx660 is starting his winter rebuild of his trx 878 and has asked me to post on here. So far paul has fitted a JE big bore kit and had zorst big bore headers made and is planning a hoast of mods for his bike which i hope to post on here. Recently he has aquired some R1 2004 usd forks (from me) yzf 750 swing arm, thunderace rear wheel. I called round to see paul today to see how he was getting on.
starting to strip bike down
motor and wiring harness out
Re: tzx660 bike rebuild
Post by alextrx850 » Sat Jan 05, 2013 9:03 pm
An R6 rear shock would probably be a follower with the quality of parts going on here..if you are , a small amount of upper reinforcement needs to be removed from the yzf rear to allow the shock resevoir to work freely..and needs to be dropped through from above...also, ive noted a few times that the side arms of the yzf are often a bugger with fouling muffler cans..a good fun set up though...looking to the 878 piston fitting...what thoughts to useing a tdm 900 barrel with the trx head..?i think i have heard someong doing that somewhere..[obv there is the frame lug issue]..
Post by dixonj » Sun Jan 06, 2013 12:27 pm
about to chop off the rear end.
to late now
trying the R6 rear end on
Paul has also machined some stainless pistons for the bluespot calipers that will be fitted front and rear
Re: tzx660s TRX bike rebuild
Post by misterdimwiddy » Sun Jan 06, 2013 3:52 pm
Any idea what year R6 this tailpiece is from?
Tempted to do this mod to mine.
Post by dixonj » Sun Jan 06, 2013 4:04 pm
1998/ 2002 5eb model same as the one my bike, will be posting all the pics of the fabrication as it progresses.
Post by misterdimwiddy » Sun Jan 06, 2013 5:44 pm
Thanks.
I will monitor progress, start buying parts and then get the angle grinder out.
thch
Post by thch » Mon Jan 07, 2013 8:07 pm
Hi.
Doing the same myself this winter - using a carbon 2003 R6 rear end:
I _hate_ welding.....
Will post pics when the project is done :D
Post by dixonj » Sun Jan 13, 2013 4:13 pm
Small update Paul turned some slugs so as to get a good strong weld on the modded rear end.
hopefully this thread will help other people wanting to do the same rear end conversion
tzx660
Post by tzx660 » Sun Jan 13, 2013 6:46 pm
thch wrote:Hi.
Post by dixonj » Fri Feb 01, 2013 3:10 pm
small update, rear all welded up just need to tidy up welds and then its off to be powder coated gloss black along with some other parts
Post by Con Rod » Sat Feb 02, 2013 3:37 am
very tidy job on the rear subframe and you get to hang on to the luggage hooks. Great way to do it. Keep it coming
Post by dixonj » Wed Mar 06, 2013 9:29 am
Quick update Paul has got his frame back from the powder coaters and looks like new
really looking forward to this rebuild
Post by Tarwetijger » Wed Mar 06, 2013 9:48 am
What are these? :?:
Post by dixonj » Wed Mar 06, 2013 10:10 am
blue one is a fzr400 race bike and the red/white is another special project Paul is building don't think i can say what it is. I am sure Paul will be on later to comment :wink:
Post by Tarwetijger » Wed Mar 06, 2013 10:31 am
FZR400RR-SP? =P~
http://www.motorcyclespecs.co.za/model/ ... p%2090.htm
Special projects are always interesting. 8)
