Brake Hose vs Master Cylinder
M.V.
Re: Brake Hose vs Master Cylinder
Post by M.V. » Fri Sep 21, 2012 12:26 am
Old thread revival!
Did anyone find out id of the rear brake hose? At a guess it looks about 10mm, but I wanna order the hose before I pull it apart...
bane
Post by bane » Tue Apr 02, 2013 7:15 am
Can anyone tell me if 5/16 (8mm) is the correct size hose I need between the standard trx front master cylinder and the m/c reservoir? I have searched the forum and the net but couldn't find a definite answer.
Bane.
M.V.
Post by M.V. » Wed Apr 03, 2013 3:20 am
bane wrote:Can anyone tell me if 5/16 (8mm) is the correct size hose I need between the standard trx front master cylinder and the m/c reservoir? I have searched the forum and the net but couldn't find a definite answer.
Bane.
G'day Bane, I think it is, I can confirm tonight for you.
bane
Post by bane » Wed Apr 03, 2013 4:15 am
Hi MV, I hope your wrong because I ordered the 1/4" (6mm) this morning....Haha...
M.V.
Post by M.V. » Wed Apr 03, 2013 11:32 am
bane wrote:Hi MV, I hope your wrong because I ordered the 1/4" (6mm) this morning....Haha...
Just measured my old reservoir, 8mm inner diameter is what you need, sorry!
But, if you get an R1 radial master cylinder & a Rizoma fluid reservoir with the 6 & 8mm outlets, you can use the hose you bought 8)
Probably cheaper to buy the right hose though...
bane
Post by bane » Wed Apr 03, 2013 12:26 pm
Just my luck.... cant pick a winner in a 2 horse race...
I contacted the seller as the item hasn't been sent yet
so hopefully I caught it in time. If not I'll just have to
upgrade to the R1 radial and be done with it....
Thanks a lot for the info M.V. At least there is a definite
answer now if anyone ever needs it.
cheers,
Bane.
M.V.
Post by M.V. » Wed Apr 03, 2013 10:12 pm
No worries Bane, that's what we're here for!
