Started this today
bubbaad
Started this today
It's getting fiddly now.....
- Tarwetijger
Re: Started this today
Err, what happens next?!
Ah, ok....a clear cover, interesting to the how it will be fixed in place and sealed.Tarwetijger wrote:Err, what happens next?!
Clear pyrex, or a clear cooking pot lid would do...handle optional
bubbaad
Was thinking mdf and gaffer tape
WHY ?
hello Mr clutch pushrod why have you fallen out...? ohhh because someone cut away all my supporting material...
bubbaad
Why do anything ?
How does the outer plastic pjate cone off.?.i need to spray mine.
- Con Rod
alextrx850 wrote:How does the outer plastic pjate cone off.?.i need to spray mine.
just 2 screw behind the alternator windings from memory
bubbaad
You're memory serves you well.......
Guessing the two offset holes on the inside photo has the screw lugs for the outer yamaha dish....on the clutch cover.Con Rod wrote:alextrx850 wrote:How does the outer plastic pjate cone off.?.i need to spray mine.
bubbaad
That's right. I'm going to drill for a further two bolts and hopefully with some suitable sealant it wont leak..............
- Rod.s
Yep the ribs take compressive loads, the flats, lateral load, it won't fail straight away...... Once it gets covered in oil it'll look decisively average, but hey it's not my bike so go crazy manhandsomejackuk wrote:hello Mr clutch pushrod why have you fallen out...? ohhh because someone cut away all my supporting material...![]()
