rear shocky
- nukes
rear shocky
Gday all, just wondering what options are available for the rear shocky as ive come to the conclusion mine is just about f#@ked. Are they an easy thing to service, not worth the effort,aftermarket prices? Any advice greatly appreciated!!
KEEP THE WIND IN YOUR FACE
Guess it's like with most things, a matter of money and interest...
I had my standard shock re-built last year, and it was an amazing feeling to have a working shock... Costed me ca 250 Euros, and that included a bit of machining things in order to get the correct sag.
With that said, I presume an aftermarket item should be better, Öhlins, Wilbers or such. I've been told adjusting possibilities are the main difference, with those You can actually feel the difference with one click. On the other hand, if Your only commuting, and go for some twisties in the week-ends, I suppose it wouldn't be worthwhile, I think the cheapest Wilbers shock is something like 450-500 Euros?
The YZF750 rear-shock is obviously the same as the TRX's, so that gives You a slightly bigger supply.
- phuk72
twolfe
- nukes
- Max
- Janitor
Nukes, is yours a Japanese import model? If so, the spring is way to soft for round eyed gaijins. Standard JP model rear spring is 8kg, I put a 9.5kg Racetech on mine and low and behold, magic. I'm starting to run out of compression response now as the shock has been worked hard but a rebuild should fix that.
And yes, it's still not as good as a 'real' Ohlins.
What is your weight (in gear) BTW?
- nukes
shit max and we havent even been on our first date yet!!!!!!!
weighed in at 102kgs plus leathers which are f@#kin heavy things, little bit less after a
and a
. As far as i know its not a Japanese import model but i think the ks have something to do with it. I'm sure its never been reconditioned though it does have lockwire holes dotted around the joint so i think it has a fairly chequred past. My mate with the bike shop up here reckons around $150 to get it done but there isnt anyone up here to do it, so he has to send it away.
What poundage are you Max as a comparison for the spring weight?
- Max
- Janitor
- Waz
Nukes, you'd definately need a heavier spring at a healthy 102 + kg. 10.5kg at least. I don't think you'll get away with not having to send the shock away for mods. My preference would be Terry Hay at Shock Treatment in NSW for Racetech or Peter at Promecha for K Tech in Vic. I chose Promecha and found them excellent. Either will be able to advise on spring rate and then shim the shock to suit your riding style and spring rate.
Once a TRX lover, always a TRX lover.
twolfe
- nukes
gday Twolfe, dont mind if it costs a bit as long as the bugger is done properly. Thanks for the reference Waz ill give em a tingle during the week. Bye the way hows the water situation going down there, my rellies are saying its still dry as a nuns nasty even with the occasional storms passing thru. Lucky stroke you dont have to drink your own P@#s though. My old man reckons you should only drink out of bottles anyway[black ones with xxxx on them]
- Max
- Janitor
Peter850
I had my front forks fully done by MPE ( Pual Baericke - 07 5439 0088 ) and at the same time he serviced the rear back to stock for around the price you said . Should have swapped springs at the same time but the cash wasn't there. He does great work and has guy's who send there MX bikes down from FNQ just so he can work on then, he even has my dirt bike forks at the moment. I think he's the only Race Tech qualified tech in Queensland. Cheers.
Suncoasttrx in another world.
- Max
- Janitor
