by Yoozy » Sat Jul 13, 2013 10:56 am
Bit of a bummer on the caliper front. I had the Brembo discs already, and I've read that with them you don't have to chop anything to get the blue spots to fit the yzf750 forks. Well,,you do. Bugger.
I've had a play with the rear pegs. Sawed the footy peggy bit off and started to shape them. Only roughed it atm but I reckon they'll look oreet polished up. Might put a couple of blobs of solder in the craters
bubbaad
by bubbaad » Sat Jul 13, 2013 11:03 am
Looks like it will be sweet when finished.......You can get some nice aftermarket exhaust hangers, 'Kayla' on here sells them.
by Yoozy » Sat Jul 13, 2013 12:39 pm
I know, I'll get some when I've fuk't these up
by alextrx850 » Sat Jul 13, 2013 9:29 pm
Should have photos here on the trimming needed to fit blue spots tp your yzf forks, Yoozy
No issue to the strength to the lowers that I've known.
Also, 98-99 R1 axles fit the yzf front as well...lighter to boot.
by Yoozy » Sat Jul 13, 2013 10:28 pm
alextrx850 wrote:Should have photos here on the trimming needed to fit blue spots tp your yzf forks, Yoozy
Arf an hour a side with a grinder, file and a dremel and bobs yer nana
Get me top yoke Tuesday
What I do need is some dandy new levers. What about these in all black with red adjustiicators ?
http://www.aliexpress.com/item/Motorcyc ... 57626.html
Anyone bought off that place ? I'd never normally buy unknown stuff but ????????
by Yoozy » Sun Jul 14, 2013 12:38 pm
by coxylaad » Mon Jul 15, 2013 1:28 pm
looking good there nob
by coxylaad » Mon Jul 15, 2013 1:29 pm
whoops didn't realize you have changed your name, now it looks like I am abusing you
by Yoozy » Mon Jul 15, 2013 1:48 pm
Does that make me a self harmer
by coxylaad » Mon Jul 15, 2013 2:13 pm
honestly I prefer nob lol
skull-candy18
by skull-candy18 » Mon Jul 15, 2013 6:20 pm
That looks great ! How hard was the tail to fit ? I prefer that over the r1/r6 tail.
by Yoozy » Mon Jul 15, 2013 6:53 pm
Lots of squinting, swearing, putting on and taking off involved. Helps if you've got a welder mate with a load of patience
by handsomejackuk » Mon Jul 15, 2013 11:55 pm
dixonj wrote:Headers look the dogs bollocks, even cleaner than handsomejacks
those headers are real nice i got to admit mine are not that good.. i havent dropped mine off this year though...
but will do shortly though after seeing those...
nice job well done, what did you use.. to get them that good ?
by handsomejackuk » Tue Jul 16, 2013 12:02 am
Yoozy wrote:Bit of a bummer on the caliper front. I had the Brembo discs already, and I've read that with them you don't have to chop anything to get the blue spots to fit the yzf750 forks. Well,,you do. Bugger.
I did a similar thing years ago with the rear footpegs, I had a spare set i bought off someone.. mine never looked good as the originals though...
there were loads of craters in there... could you get a piece of aluminium plate welded over the top to give you a smooth finish.. just a thought ???
If you know a good ally welder, or get them welded up..
Al.
by Yoozy » Thu Jul 18, 2013 2:16 pm
I feel like I'm getting somewhere now. Both wheels nailed on, time to start putting all the fiddly bits on. I'm hoping that top yoke is the last of the big spends now annall
