Exhaust Downpipe Removal
Re: Exhaust Downpipe Removal
Post by cobbadiggabuddyblooo » Sat Mar 01, 2014 2:34 am
[quote=Image[/url]
And lots of IMAL spray and a big hammer!! [-o<[/quote]
That's a novel way :o Hang it by the pipes and beat the s€#t out of the motor.
:lol: :lol:
Stu99
Post by Stu99 » Sat Mar 01, 2014 8:30 am
And just let gravity do all the hard work. :lol:
emway
Post by emway » Sat Mar 01, 2014 9:28 am
No, really. The chisel did all the work :shock:
Post by Tarwetijger » Sat Mar 01, 2014 10:48 am
cobbadiggabuddyblooo wrote:Is it gpz900 Kawasaki 2 piece flanges that you can replace them with if need be??? ..
A little late response, but for future reference: yes you can use these.
http://www.freebits.nl/images/794gpz_90 ... 14_002.jpg
http://www.freebits.nl/images/869gpz_90 ... 14_004.jpg
From a Kawasaki GPZ900R (but they might be called differently in/on others countries/continents, something with 'ninja' etc.)
emway
Post by emway » Sun Mar 02, 2014 9:01 am
And if you want to make them yourself. Here is a drawing. (thanks to the German forum) =D>
Kev44
Post by Kev44 » Thu Jun 12, 2014 9:42 am
Same problem here now :( been soaking in WD40 for 2 days and not moving!
Gonna have to get some heat on i reckon .............
The day went so well stripping the bike down had leave engine on floor with exhaust still attached
TRX850 Cafe Racer, Ducati 749 Hybrid, Aprilia SXV550, KTM525EXC, new cafe racer project watch this space!
Post by Tarwetijger » Thu Jun 12, 2014 11:56 am
Kev44 wrote:Same problem here now :( been soaking in WD40 for 2 days and not moving!
http://www.trx850.com/phpBB_forum/viewt ... 09#p104309
emway
Post by emway » Thu Jun 12, 2014 4:09 pm
After removing the exhaust i drilled the flanges out with 1 mm more .
Heat didn't do the trick here :evil:
Kev44
Post by Kev44 » Thu Jun 12, 2014 4:28 pm
Bugger if heat don't work its cut em off ffs :evil:
johnktm
Post by johnktm » Fri Jun 13, 2014 12:35 am
I've just been through the same thing,I used loads of WD40,two small pry bars a hammer and a long socket that was just bigger than the stud diameter.And a load of patience.
Just had to keep soaking in wd,and working the collars back and forth tiny amounts prying forward and tapping back using the socket like a drift,plenty of sharp taps with a light hammer all around the collar,took around 3 hours of swearing and sweating but eventually got them off intact,but a little "bruised".
Kev44
Post by Kev44 » Fri Jun 13, 2014 8:07 am
Nice shiny exhaust you have there pity mine wasn't like that don't know what to do with them once i've got them off, might have to wrap them
Rod.s
Post by Rod.s » Fri Jun 13, 2014 9:34 am
Then remove the studs and replace them with bolts :D
Kev44
Post by Kev44 » Mon Jun 23, 2014 9:07 am
And then when the studs don't come out?
You're in a world of hurt
Given up on mine now going to cut collars off :evil:
Kev44
Post by Kev44 » Mon Jul 21, 2014 9:40 pm
Well after the struggle of getting them off the result of many hours of rubbing down and only 2 runs with the coarse mop this is the result, well chuffed :D
bordem88
Post by bordem88 » Sat Oct 18, 2014 1:28 pm
This has been a huge help.. got a work mate been tryin to get his off for a week to no avail. I'll try the chissel idea tomorrow and see how we go... cheers..
