im gonna remember that one
Down Pipes
- Quan-Time
Re: Down Pipes
now ive seen it all.
Terzikat
Re: Down Pipes
Had exactly the same problem with mine. I soaked it in all kinds of stuff over a two week period and it didn't work. Then I tried the application of heat and that didn't work either. Eventually I resortedto griding away the collar and splitting it with a chisel (!). This way pretty extreme but what I found when I had done this was that the manfold studs and the collar had corroded and become permanently bonded together - there was no way they would ever come apart again............
- M@thijs
Re: Down Pipes
I did some of the above lines with a grinder in my handJohn M wrote:Give this a go:
ã‚ãªãŸã‹らå–れるよã„æ¯ÂÂfuk'r ç„¡ãÂÂâ€â€
Or, "come off you no good mother fuk'r"
thanks, babelfish
now busy witch the high mounts
